For Sale NM- poverty pack built 80 series . clean!!!
Status
Not open for further replies.
Year
1996
  1. 80 Series
Mileage
250000
Color
Red
1996 Toyota Land Cruiser (Series FZJ 80)
Medium Red Pearl (3H4)
250k miles
Rare slicktop (no sunroof, no roof rails) means more headroom and no leaks
Factory tow package with transmission oil cooler
Modifications include:
Ironman 4×4 America Foam Cell Pro 2″ suspension lift kit, steering damper, and shocks
BFG K02 315/75 R16 (35” dia) tires installed at 225k miles
4.88 gears installed May 2023
Slee ShortBus front bumper
Warn 9.5 XP-S winch
Ironman 4×4 America snorkel
FrontRunner Outfitters Slimline II roof rack
Metal-tech 4×4 rock sliders
4x4Labs expedition-style single swing-out rear bumper with a high-lift jack
New Pioneer head unit w/3 year warranty installed Jan 2024 (Cartoys); Kicker front speakers
Trailer brake controller
LED low and hi beam headlights
Radiator hoses replaced Nov 2022
A/C compressor replaced July 2019
All new window runs installed Nov 2020
New door glass inner and outer wiper seals installed May 2023
New OEM front axles installed July 2020
New link rod, front and rear suspension and sway bar bushings installed July 2020
Front brake rotors and pads replaced Sep 2020
New exhaust (including cats, muffler, y-pipe, flex joint) installed over last 2 years
“Pesky heater hose” replaced
New radiator Aug 2022
New engine and transmission mounts April 2023
New OEM cap, rotor, wires, plugs, air and fuel filters, pcv installed May 2023
New battery Jan 2024
New belts Nov 2024
New headgasket / top end 2025
Zero rust !!!
PM for more photos / info
18,900$
Ah, is this the one that failed to sell on BaT or CaB many years ago? It has a repainted roof, right?
Yes it’s this one from 5 years ago that didn’t meet the reserve and was sold privately
Not many out there 😎
Yep! Nearly identical to mine when I bought it.
You do have third row seats and rear window sliders. Mine didn’t have those. Otherwise identical!
Also requires cutting holes in the fender 😈
Imagine the cutting it takes to stuff 40s 🤣
Fenders are easy to replace and repaint. I’m not looking to go hardcore crawling with but more camping rig, so I’d want something that’s still nice.
The snorkel is 2 small holes that can be welded in much easier than replacing fenders
this looks like a really nice deal to me for a turn-key 95-97 truck.
80
2025 head gasket kit -400$
2025 head machining 200$
2024 Belts 65.00$
2024 trailer brakes 500.00$
2024 alignment 110.00$
2024 transmission flush / t case / 520.00$
2024 exhaust flex joint 530.00$
2023 engine and trans mounts 1119.00$
2023 4:88 gear parts only 840.00$
2023 regear labor / rear glass seals /cap rotor plugs wires ,pcv ,fuel filter ,led low and high beam lights , brake flush , new muffler 9,340.00$
2022 radiator silicone hoses 450.00$
2022 radiator 1940.00$
2022 hood struts 50.00$
2022 front and rear cats / tuneup 3,000.00$
2020 K02 35s 1500.00$
2020 front axle rebuild new inner and outer axle shafts sway bar bushings reseal PS pump high pressure hose fuel filter service transmission panhard bushings - 8,400$
2020 brakes/repack bearings 800.00$
2020 seat cushion 200.00$
2020 rock sliders 1300.00$
2020 parking brake 220.00$
2020 radio 700.00$
2020 steering seal/steering shaft 1000$
2020 headlight adjustment 104.00$
2020 window runs 1660.00$
2019 tie rod end kit 114.00$
2019 tie rod labor n front bearings 660.00$
2019 headliner 515.00$
2018 snorkel 200.00$
2019 Ironman lift 2500.00$
2019 slee front bumper and winch 1400.00$
2019 AC compressor and belt 720.00$
2019 roof rack 1700$
2019 4x4 labs rear bumper - 2000$
44,700$
Status
