New LC Differentials (18 Viewers)
Looks like they are shared with LC300. IMO that's great news. Same as Tacoma, non-hybrid Tundra as well. Unifying all of the powertrain should make aftermarket gearing easy and available. Presumably the off the shelf GR Sport front locker diff is a bolt in swap??
I had some other questions/comments if anyone has seen the inside of the LC300 diffs:
I notice that both front and rear diffs have replaced the outer pinion bearing with a ball bearing instead of an angled roller bearing. I don't understand why exactly they would choose to do that. How does that work with the bearing preload. I can't think of any other application I know of where you are preloading a rotating assembly with a roller bearing on one side and a ball bearing on the other. Ball bearings generally don't tolerate side loading as well as roller bearings and I would expect the ball bearing to wear faster and lose the preload more quickly in this case than the old roller design.
EDIT: On closer look - it appears to be a single row angular contact ball bearing (basically a ball bearing that is designed for high axial load in one direction). But then why use a ball bearing instead? Friction? Sealed bearing? or ?? Any experts in bearings that could help me understand why?
Additionally, you would typically use setup bearing races to set up the pinion depth. How is this done with the roller bearing that doesn't have separate races? Do you have to press the thing on and off every time you adjust the shims? And how is it pressed on? Can it be pressed out with just a shop press or is a specialty tool required because roller bearings normally are not preloaded at all in a sideload. You normally just capture the center race, but here it presumably requires the outer race to have a very tight friction fit into the case and the inner race then presses onto the pinion shaft. Can you get that out without destroying it? Or is it a one-time use item? Pushing the pinion out seems straight forward. But getting the bearing back out after looks challenging.
Is the crush sleeve gone? The pinion is now very short. But I don't see a crush sleeve or room for one. What is used to set bearing preload? Shims? Nothing? or ???
Is it a sealed bearing? That could be really useful if so. Possibly that's the reason for the change? Sealed pinion bearings would be a potential game changer for use as high pinion in other applications. Outer pinion bearing oiling has always been a challenge for higher angle diffs. This may end up being a very popular differential for afermarket use in old junk like my FJ40 where pinion oiling is a constant worry to me due to higher angle required by the short wheel base.
Second area of interest is the left hand side inner CV shaft support. The dreaded needle bearing! Teh diagram doesn't seem to show any bushing or bearing on that side (green arrow). Anyone have any idea whether that's a bushing, bearing, or ??? Does it just ride directly on the carrier machined face? The other similar images from prior units clearly shows the needle bearing. This one has nothing but an oil passage it looks like.
On the right hand side the support bearing is now much smaller. Probably still adequate, just something I noted compared to the prior design.
Sorry for the grainy pic.
Old one:
No insight here on your questions, but just a few of my observations looking at some of the specs...
Appears it is getting the better double offset (versus tripod joint) inner front CV axles, and both axles are the same, in contrast to the new Tundra, according to Tinkerer's video.
The diff locking mechanism is changed from an external motor driving a sliding collar to a magnetic lock ring engaging the side gear. Looks similar to an Eaton. Perhaps this will provide more reliable and faster engagement than the older Toyota elockers.
It's interesting how variable the gear ratios are. 3.31 all the way down to 4.78. The current 150 platform has a unique rear diff and the only available OEM ratios are 3.73 and 3.91, neither of which are ideal when the vehicle is modified/lifted. This will make it much easier to mix-and-match with used OEM parts when these vehicles start really getting modified on the secondary market in 5+ years.
The 4.78 comes with the 2TR-FE engine, which is 2.7l NA I4 with a whopping 158hp. It won't be offered in the US, so you'll probably never see it for sale, other than order from Toyota parts dept.
For the 150, you can get a 4.56 ring and pinion that was from the elusive 4 cylinder 4runner they offered the first couple of years, or go aftermarket. I've had nitro 4.56s in my 5th gen 4runner since 2014
It's pretty easy to order the non-USA parts inexpensively from Partsouq.
would be interesting to see what people mix and match over the years as we get more familiar with these vehicles/TNGA-F and what works best for each application/mods; etc.
Lots of fun parts to play around with!
and they arrive really quick too!
Agreed! Nominally slower than ordering them from a US-based supplier, and sometimes half or two-thirds of the cost.
Just for folks who maybe didn't look super close - the 4.78 diff ratio is a different rear axle size. It's the 8.2" diff rear and 8" front clamshell rather than the 8.9/9.5 combo.
What's interesting is that those new parts might be direct swap for the current GX460/4Runner. So - maybe there is now a new OEM setup for those folks. But they don't fit the new LC250 in the USA version.
Anyone know what axles are under the bottom trim new Tacomas? I thought they were going to be an 8 or 8.2 rear axle for the lower end of the trim range with the low power engine tune. Might be the same as what's in the 2.7??
Am I reading all this right? Seems like the "TNGA-F" platform has a large truck scheme and a small truck scheme.
The TNGA-F platform allows Toyota the flexibility to have certain vehicles (Tacoma, GX550, LC250, 4Runner TBD)) running smaller diffs and others vehicles (LC300, LX600, Tundra, Sequoia) with larger diffs? They do not appear to be in fact identical has has been widely touted and publicized.
If I am reading this right the "Land Cruiser" as we know it in the US market isn't sitting at the big boy table anymore.
On the J252/GX550, what is the other front diff option? SD20D is shared between the LC250 (only option) and the GX550 at 8.2" but there's another SD22B (8.7") - but I don't see anything in the US materials showing a different front diff for the GX.
Also, it looks like rear diff on the overtrail GX is different from the LC250.
I'd really love a deep dive as to how these vehicles are different.
from the images above it seems the LC250 get smaller front and rear diffs than the VJA252 GX 550.
The above info I posted is for the global LC250 which doesn't get the hybrid T24A and includes the non hybrid variant of the T24A.
I had assumed maybe the US spec hybrid would get different diffs -
but if you see the specs for the global GX varient with the smaller engine ( T24A hybrid - same as LC250 engine ) it also has the smaller diffs.
So out of all the 250/252 series vehicles, the only one with the larger front and rear is currently the VJA252.
Also due to modularity of the platform - if need arises in future to mix and match whatever parts - it is easier than ever.
Curious to see what they would end up using for the hybrid J300/310 when that comes out eventually...
