My 69' fj55 has very dim headlights; I always drive with my brights on and have never been 'flashed'. I'm sure the wiring is also pretty old and borderline.
So I was orderning some parts and upon impulse bought some Hella H4's and the Hella relay w/ fuse from MAF. I understand the basics of wiring in a relay, but am confused. The bulbs in the Hellas are 55/65. To use these, do I need two relays? - a seperate relay for both the high and low beams? The relay that came with the lights is a four prong (30: Power, 85: Ground, 86: Trigger, 87: Headlight Output, or so I think). Also, the Hella Relay is only a 15A, is that sufficient? Or is a 30A more appropriate?
These bulbs are replacing my stock bulbs, so I will be utilizing stock switches and do not want to kill them.
Thanks
Thanks
