Greetings,
I have a 76K20 Chevrolet pickup truck with a 350 engine 4spd trans that the ignition switch is broken that I would like to try to get running. What happened is the ignition became jammed and it would not turn. I have started to disassemble the steering column to replace the actual ignition with a new key, but life gets in the way and I just can't finish this job. The truck has been sitting now for about 5-6 months in my yard. I would like to try to fire it up because I hate things to sit because more problems just arrive from sitting.
I use a remote starter switch (similar to OEM tools 25331) on Kubota diesels and small engines at work sometimes to get them running or move them back to the shop. I have never used the remote switch if the ignition is not on though.
How could I use the remote starter switch on the K20 just to fire it up until I get the switch fixed. Once running how could it be shut off?
Thanks for any help
Sean
Thanks for any help
Sean
