Need Help Ironing Out Some Small Issues on the 40
Charlotte, NC
Hey everybody,
Been awhile since I've posted up. Haven't dropped off the face of the earth, just been busy with school, work, and what not. Anyways after having the 40 down for the past several months to fix several nagging issues with her (clutch, brakes, carb, rust, paint, etc) I finally got everything sorted out (or so I thought) and got the old girl up and driving again this past Sunday! Well here comes my problems. The first has to do with the brakes. My original problem when I parked the truck was that one of the wheel cylinders on the passenger side rear was leaking fluid. So I took it and all the rest of the cylinders on both sides of the rear and had Dave Rushing (roadstr6-Dave feel free to chime in here) rebuild them all. In the meantime I went ahead and ordered all new shoes and springs from Beno to replace the old nasty worn out ones. After I got the cylinders back from Dave and all the parts in, I swapped everything out, and replaced everything. Then I adjusted the new shoes on either side and bled both sides (I have one man speed bleeder screws on that I replaced the old ones with when I first got the truck). Well on the passenger side rear, after everything was done I noticed fluid leaking from the bleeder screw. It was tightened all the way and I double checked everything. I then went and bought new bleeder screws and replaced them just to be sure. Still got leaks. The threads aren't cross threaded or stripped because the bleeder will thread in fine. So on Sunday after I drove it, I put vice grips on the soft line in order to not get air in the system and then I removed the bleeder screw and swabbed a q-tip down in the hole of the cylinder where it threads into. Pulled out some little gold flakes of metal which I'm sure were preventing the bleeder from sitting correctly. Put bleeder back in after that and still got leaks of fluid from it. My theory is that the gold flakes of metal were from the part that is inside the cylinder that the bleeder presses into/sits against (the bleeder was in perfect shape when I took it out). Does this sound probable or am I too farfetched? Is my best bet to just go ahead and buy a new cylinder and replace it in order to get the bleeder to seat in all the way?
My second problem is some carb troubleshooting. Dave Rushing rebuilt my carb for me as well (big thanks to Dave and again feel free to chime in here). Well Sunday when I was driving it she drove great, but I had to have the choke pulled out in order for the truck to fire and to stay on. As soon as I pushed choke in truck would shutoff. Obviously carb needs some adjusting now that I've got her up and running, and unfortunately the carb is one thing that I'm not versed in and as of the moment it is over my head. I also lack a vaccum gauge to mess with it myself (and I don't want to mess it up). I asked Dave R. what he thought and he says he thinks it is starving for fuel at idle and could be one of three things: 1)a vaccum leak, 2) idle circuit is clogged, 3) linkage and adjustment is not right. I have no clue when it comes to this. What do y'all think? I don't believe that it could be the carb is gunked up seeing as it was rebuilt and right before I parked the truck I replaced the fuel filter and while I had the truck down, I put a large chain down in the tank and shook it around with acetone and mineral spirits several times to clean out the rust and gunk that was or could've been in it. Obviously the truck should run without choke being pulled. I'm just not sure what to do on this. Any help/advice would be greatly appreciated. Thanks.
-Brysen
Guys,
Brysen needs someone to come by his house in Charlotte and spend a couple of hours helping him sort out these issues. I have been assisting him when I have time but my daughter is going in the hospital for major surgery tomorrow. I will be out of pocket for a couple of weeks minimum. Brysen's getting close. He just needs one last push to get him back on the road.
Question to the experts....Are both ports on the rear cylinders the same thread? By ports I mean one for the bleed screw and the other for the hard line from cylinder to cylinder. It is possible that I assembled one of the cylinders backward so that now Brysen is having to put the bleed screw in the port where the hard line went before. If the threads are different then this is his issue and he's chewing the threads off his bleed screw on one cylinder.
I did rebuild the carb. It should be clean. The mixture needs to be set as well as the idle. I believe that once this is done, he'll be fine.
If anyone can lend a hand, please do. It's spring. He's 16. He's been wrenching on this beast all winter. I know he's dying to get some seat time in.
Thanks,
Dave
I know i live down the street from him but my long days already started. I dont see my work slowing down for several weeks to the point i will be getting one more van on the road soon. Sorry but i cannot help right now.
I think the seat on then bleeder is gone. I dont know if there is a way to get a new seat on it.
Guys,
Off topic, but I hope all goes as smoothly as possible Dave.
I had mentioned to him yesterday that I thought back in the old days you could drill and tap in a replacement brake bleeder. Not sure if that is still something available. Thread size shouldn't make a difference. It was a drill and tap and then install a new seat. Just an idea. If the seat is gone, then replacement is best, if parts are available.
The idle solenoid should be easy to check.
He was asking me for names of someone to take it to in Charlotte area to look at things. I say hold out for a little while and see if someone has the time to look at it. Chasing problems like that can get expensive.
Brysen..Give me a heads up next time you need the sand blaster and I will work on a window you can see through.
Shane
I barely have enough time to gas up and eat for another 3 weeks or so but I'll be happy to see it running again then.
I'm obviously not the guy for carb issues. No knowledge of the brake workings, either, but I'm sure they'll both be figured out pretty quickly.
Brysen has done a LOT of stuff since he's had it down and it's looking better than I bet he imagined it would for doing much of it himself.
I'd also like to say that he now has the classic adult problem of steady income but no time!
...via IH8MUD app
Somebody cover some of my gas and some coffee and I can make it out there one day.
This Is the best offer you have received for help. I will take him on that.
Rafael (@Roxx), if you'll committ, I'll match your $$$ to help Brysen get up and running.
MUDfunding! ;)
Are you serious!? I'll take you up on that if you are. We'd just have to figure out a time and day that would work. Right now Mondays are my only off day from work but I could take off a day. Let me know if you are.
...via IH8MUD app
Shane
Thanks Shane! Yeah I figured I'd ask if anyone knew of anybody to take it to since everybody I've asked said they're booked up and I've got neither the tools or knowledge of the carb work. On a side note, does anyone know of any good semi cheap exhaust places in Charlotte that I could take it to once I've got her back driving? I've still got to get the pipes replaced running down from the headers. Dave told me one place but I've yet to check into it since Im not able to take the truck yet. I was thinking of just straight piping it and not running a muffler. It's in the way anyways. What do y'all think on that? I also just want to say that you guys are beyond great and I really appreciate all the advice, help, and knowledge I've received from everyone more than y'all know. There's no way in heck that I would've got anywhere near this far with it without y'all. I appreciate all the offers to pitch in for Darin too, but if he's serious I'm more than willing to pick up the tab.
...via IH8MUD app
