- Joined
- Apr 14, 2004
- Threads
- 1,451
- Messages
- 36,634
- Location
- 818-953-9230
- Website
- www.marksoffroad.net
And while you’re changing fuel filter...you might as well change out any soft fuel lines.Gasoline in my oil.......sniffed the dipstick this morning. That dont sound right.
Who took over for cdan? He was my go to guy for oem parts that my local dealer would hold hostage.
How many bananas is a fuel pump change? Any other items while Im in there?
Mech fuel pump.
Oil change plus filter.
Might as well change fuel filters while Im in the vicinity.
Plugs and wires.
Cap n rotor.
Fuel pump changeout is easy peasy. Only slightly tricky part is getting the right pump-if I recall there are different spacer thicknesses, etc. If you get it from Mark, you’ll be good to go.How many bananas is a fuel pump change? Any other items while Im in there?
You’re fine. Go find something else to worry about!1. Idle mix screw will affect only if its almost all the way in, around 1.5 to 0. Right now set at 2 turns out.
2. Solenoid is working. Disconnect black wire, engine dies.
3. No gas at idle, that pic was taken after adjusting my throttle cable, working the pump to get that little barrel end into the linkage. I noticed a vacuum leak there prior, and carb cleaner after spraying into idle solenoid circuit.
If that's acceptable, I will carry on, booster leak and suspension are next. Thanks edwjmcgrath!
