Does that truck have an EGR still on it? Most idle probs that are not hoses are brake booster or EGR.
You say you have a vac advance, can you test the vac diaphragm, and see if you get any arm movement?
Try cleaning the coil hold downs at the bolts at the base, and running a wire from the ignitor case on top to a solid ground, that should give it good electric ground.
If it is blowing that much pressure into the coolant, pressure is leaking into the cooling system somewhere. maybe head gasket leaking at front of head into the thermostat area? Would prob figure to do valve seals, and head gasket, and may be enough.
65swb45 helped me get set up with a vac advance dissy w/ Pertronix. Cool thing is it works great with stock coil. I was amazed how much it improved my 71 F.
