Need alternator or sub for 1989 FJ70 (1 Viewer)
grayfj62turd
Austin, TX
I have a 1989 FJ70 that needs a new alternator. Part number shows 27060-61060 in Megazip but $1625!! Geez - is there a rebuilt unit that can be used instead of this gold plated unit? I have a 3F 12v system. Thanks !!
Remove your alternator, have it sent to Mosley Motors in Memphis, TN and he will rebuild and send back good as new. @FJ60Cam
Also, your alternator is discontinued. It is no longer available from Toyota. No matter what a website says about availability.
They are $450 + $133AUD with shipping from All Fourx4 Spares. They are saying its a "high quality aftermarket part"
Maybe a dumb question but is this not the same alternator as in a 3F powered FJ62 or maybe even from a 2F 40 or 60 ? If that is the case there should be plenty aftermarket alternatives.
There is a number of options. The FJ80 is another one.
Thanks guys! Toyodiy had several part numbers cross referenced
I’m not sure if the fj60 or 62 will work. TOYODIY shows the parts number made for the truck but nothing comes up under FJ62
This is from the allfourbyspares that it replaces I dont know which is which 27060-61090 27060-61060
Most of the part numbers in Australia for 3F are 45 55 or 65 amp for OEM (if they existed)
The aftermarket ones are 80 amp
This one fits all landcruiser with 3F from 85-92. Note dimensions at the bottom
TOYOTA LANDCRUISER FJ62 3F OHV 12v CARB 6cyl 4.0L 4sp Auto 4D Wagon 4WD [01/85 - 12/90]
TOYOTA LANDCRUISER FJ62 3F OHV 12v CARB 6cyl 4.0L 5sp Man 4D Wagon 4WD [01/85 - 12/90]
TOYOTA LANDCRUISER FJ70 3F OHV 12v CARB 6cyl 4.0L 4sp Auto 2D Hard Top 4WD [01/85 - 09/92]
TOYOTA LANDCRUISER FJ70 3F OHV 12v CARB 6cyl 4.0L Man 2D Hard Top 4WD [01/85 - 09/92]
TOYOTA LANDCRUISER FJ73LX 3F OHV 12v CARB 6cyl 4.0L Man 2D Wagon 4WD [01/85 - 11/92]
TOYOTA LANDCRUISER FJ75 3F OHV 12v CARB 6cyl 4.0L Man 2D Wagon 4WD [01/85 - 11/92]
TOYOTA LANDCRUISER FJ75 3F OHV 12v CARB 6cyl 4.0L Man Cab Chassis 4WD [01/85 - 11/92]
TOYOTA LANDCRUISER FJ80 3F OHV 12v CARB 6cyl 4.0L 4sp Auto 4D Wagon 4WD [12/89 - 08/92]
TOYOTA LANDCRUISER FJ80 3F OHV 12v CARB 6cyl 4.0L 5sp Man 4D Wagon 4WD [12/89 - 08/92]
TOYOTA LANDCRUISER FJ80 3F-E SOHC 12v MPFI 6cyl 4.0L 4sp Auto 4D Wagon 4WD [12/89 - 08/92]
TOYOTA LANDCRUISER FJ80 3F-E SOHC 12v MPFI 6cyl 4.0L 5sp Man 4D Wagon 4WD [12/89 - 08/92]
Adjusting Hole Diameter M8 x 1.25
Inside Mounting Legs 80mm
Pin Code IR7
Pivot Hole Diameter 10
Power Rating (Amp) 80
Pulley Outside Diameter 82mm
Pulley Section B
Regulator Type Internal
Suits Unit Make Denso
Voltage 12
Alternator Mount Twin Leg
Mount Cnt to Cnt 168mm
The Autozone alternator I grabbed was a Duralast, Part 14836.
Rockauto also has them... for a 1988-1991 Land Cruiser... different brand than Duralast, but same 80Amp upgrade.
Buyer Beware... these discount alternators are chincy Chicom stuff.
