This is from the allfourbyspares that it replaces I dont know which is which
27060-61090 27060-61060
Most of the part numbers in Australia for 3F are 45 55 or 65 amp for OEM (if they existed)
The aftermarket ones are 80 amp
This one fits all landcruiser with 3F from 85-92. Note dimensions at the bottom
TOYOTA LANDCRUISER FJ62 3F OHV 12v CARB 6cyl 4.0L 4sp Auto 4D Wagon 4WD [01/85 - 12/90]
TOYOTA LANDCRUISER FJ62 3F OHV 12v CARB 6cyl 4.0L 5sp Man 4D Wagon 4WD [01/85 - 12/90]
TOYOTA LANDCRUISER FJ70 3F OHV 12v CARB 6cyl 4.0L 4sp Auto 2D Hard Top 4WD [01/85 - 09/92]
TOYOTA LANDCRUISER FJ70 3F OHV 12v CARB 6cyl 4.0L Man 2D Hard Top 4WD [01/85 - 09/92]
TOYOTA LANDCRUISER FJ73LX 3F OHV 12v CARB 6cyl 4.0L Man 2D Wagon 4WD [01/85 - 11/92]
TOYOTA LANDCRUISER FJ75 3F OHV 12v CARB 6cyl 4.0L Man 2D Wagon 4WD [01/85 - 11/92]
TOYOTA LANDCRUISER FJ75 3F OHV 12v CARB 6cyl 4.0L Man Cab Chassis 4WD [01/85 - 11/92]
TOYOTA LANDCRUISER FJ80 3F OHV 12v CARB 6cyl 4.0L 4sp Auto 4D Wagon 4WD [12/89 - 08/92]
TOYOTA LANDCRUISER FJ80 3F OHV 12v CARB 6cyl 4.0L 5sp Man 4D Wagon 4WD [12/89 - 08/92]
TOYOTA LANDCRUISER FJ80 3F-E SOHC 12v MPFI 6cyl 4.0L 4sp Auto 4D Wagon 4WD [12/89 - 08/92]
TOYOTA LANDCRUISER FJ80 3F-E SOHC 12v MPFI 6cyl 4.0L 5sp Man 4D Wagon 4WD [12/89 - 08/92]
Adjusting Hole Diameter M8 x 1.25
Inside Mounting Legs 80mm
Pin Code IR7
Pivot Hole Diameter 10
Power Rating (Amp) 80
Pulley Outside Diameter 82mm
Pulley Section B
Regulator Type Internal
Suits Unit Make Denso
Voltage 12
Alternator Mount Twin Leg
Mount Cnt to Cnt 168mm
Find many great new & used options and get the best deals for ALTERNATOR suits Toyota Landcruiser FJ62 FJ70 FJ75 FJ80 3F 3FE Engine Round Plug at the best online prices at eBay!
www.ebay.com.au
