- Thread starter
- #121
Why not put the idler back where it belongs?
Thank you Darb. Unfortunately, the oil leak is behind the oil pump cover, between the engine block and the timing chain cover. I replaced the oil pump cover o-ring, twice, to verify that the oil leak is not from the oil pump cover. Thanks againYes both were removed to get front cover off. Although if only your oil pump cover o-ring is leaking the whole timing cover does not have to come off. The front timing cover has 3 o-ring seals and the crank seal.
As Robbie and Dan suggested, replace those cogged belts with a matched pair from Cruiserdan or your local Toyota dealer and reinstall the idler pulley (which can also be purchased from Cruiserdan.)
-B-
