Oil pan had a very slight leak, changed oils and doesn't leak anymore....anyone ever had that?
SE Michigan
I had a very slight oil pan leak, like less than a few drops a week on the garage floor. Last oil change used a different oil and the leak appears to be completely gone....obviously viscosity and things like that but just curious if anyone else had ever had this happen.
Definitely not complaining!
Did you go from synthetic to standard?
Enjoy it.
While it lasts.
Unfortunately, motor oil won't repair aging seals and FIPG.:mad::meh:
My old wrench swore that Valvoline MaxLife would/could enhance gasket seals and he did lot of 80 series work.
3FE uses an oil pan gasket. 1FZ does not.
Did you hold your tongue just right, cross your fingers just so and spin backwards 3 times as you changed the oil? That is probably what did it. ;)
Mark...
