rusty_tlc
Dain Bramaged Member
x2Easy outs are the devil..
Use the acid/penetrating oil..
they always break and it's a lot tougher to remove a hardened steel ez-out than a mild steel bolt.
a couple comments...somone mentioned going to a diesel instead of a gasser...well then your gunna be looking at ALOT more money...with the domestice diesels you will have to look at a spring over or other largish lift to clear the oil pan, the other option would be toyota diesels but they are also realy expensive to swap and would require much more work then a V8 or other gasser swap would. when i was looking into diesel swaps general opinion was about i think around 10k once the smoke clears and the rig is on the road...
also...i have heard that the H55 is over rated, i have not run this tranny but from what i know you cant hit 5th gear very often unless its dead flat or down hill...
while a V8 would net you more power and be better on the road...i would think long and hard before i put a V8 into a piggie, i mean...just like any other 45 there arnt very many out there any more and once you put a V8 it might not be reversable. just m.o. personaly i tend to shy away from the V8 conversions unless the rig is dirt cheap...but thats just personal preference
I like all the OSHA approved footware.
Dynosoar![]()
Yep, flip flops and crocs are all the rage in safety shoes.
Hey Heather...who is doing the paint and body for you there in ATL? I talked to a couple guys here in Rome and they were less then interested in anything but collision work
