Update time, long informative post.
Really a 'heads up' (no pun intended) about fitting the touchscreen head unit.
As already mentioned the universal fitting brackets are anything but universal. This is probably made worse by the 'stepped' method used by Toyota on the double DIN systems, just drill and file the OE brackets, you need patience and have to keep trial fitting the lower dash to make sure when all tightened up the screen fits in the opening neat and tidy.....did I say you need patience?
Wiring is pretty straightforward once you have sussed out the wires to suit the speakers. My model has the four speaker system (two in the lower dashboard, and two in the rear doors), some models had eight speakers, that is additional units in the front doors and rear of the roof, wiring is still pretty straightforward though. An easy way to locate the wires that relate to the individual speakers is to use a 9 volt battery, simply keep pairing wires across the two terminals, you will here a speaker 'crackle' when you have a matched pair. Toyota do not list + or - in there speaker wiring diagrams, instead they use 1 and 2, in the past I have always used number 1 as the + or positive. If I am wrong then there must be a lot of deaf people out there, if wired wrong the sound is rather 'flat'.
A couple of other things I would point out, a lot of these touchscreen heads (and indeed older radios) do not like the turn of the key from ignition to cranking, it tends to disconnect the radio and then reconnects when the key is released, this is the starting system used by Toyota. I found my head unit has two options simply called 'key 1' and 'key 2'.
Key 1 was my first choice (obviously), and this caused the disconnect/connect scenario, key 2 on the other hand did work, there must be a changeover mechanism in the head unit, cranking now does not cause the interruption of the power supply.
EDIT: This morning I started the car to bring it out of the garage and I caught the radio come on and then go off during cranking I have no idea at the moment why, one theory I have is a diode failure assuming there is one or a sticking relay in the glow plug circuit, this maintains the glow plug supply for around thirty seconds, so the theory holds water.
I will look at it when I get time, this unlikely as I am spending much of Christmas with friends as from Thursday, I will definitely get back to clarify what I find.
I am still unable to drive on the road until permission is granted however, this does not stop me driving around the campo or countryside tracks. I found the screen too bright when it gets dark, in the settings you can dim the display, that is you are setting the screen display for day and night, of course like a lot of touch screens on your mobile phone, if too dim you cannot see it, and of course at night you might as well be looking at the sun! I thought the answer was in the wire that was to be connected to the headlight switch perhaps dimming the display alas no. When connected and the lights are turned on it illuminates the five touch sensitive switches, these are on/off, two for volume, one for home and the remaining one for 'return' as in previous screen. A nice touch is the graphic on display shows a small car from behind, switching on your lights the headlights on the graphic lights up, a neat touch if nothing else. FWIW it was easy to connect the light switch to the radio by connecting to the dimmer control, I know many have disconnected this, as like me found night time illumination fine when on full, but of course the wiring would still be there. On my model there are three wires for the dimmer switch, white/green trace, white/black trace, and a solid green, the solid green is the correct wire to connect to, of course you should check the wiring diagram relevant to your model....disclaimer in place.
Now having said all that I found that an icon in the top left corner if touched brings up a set of options, one of them is to turn off the screen but leaving music on, the now black screen needs a simple touch and it comes back to life. I still need to fit the reversing camera, having driven HGV's for a number of years I doubt I need it but it came with the head unit so I will, use it. Tomorrow I have a dash cam and rear cam being delivered, so will fit the rear camera when fitting the reversing camera, it's probably possible to use one camera to supply the head unit and the rear dash cam, of course fault finding becomes more difficult so will wire the two individually.
The user instructions are at best........well..... there is no best!
The answer is to 'fiddle' with the unit, you will find this is the quicker way to learn what it can and cannot do. For example getting Bluetooth to pair should be a simple affair, I found I had to switch on the front display BT then activate pairing waaaaay back in the various menus.
The quality of the display is really really great, as good as any mobile phone I have seen. Initial calibration was fussy to say the least, it took me no less than four attempts to get it to work right, interpretation of the instructions was a little difficult, and I perhaps need to share some of the blame for that? Either way once it was done the screen responded to the gentlest of touches. A point to note is I am right handed, so being in a RHD vehicle I use my left hand on the touchscreen, and yet I found the 'buttons' easy to touch without triggering the wrong one. There are soooo many menus and options for example no less than three different sat nav options, even an option to use off road or terrain maps, all the bells and whistles with amplifier outputs, perhaps there is a way to auto dim the screen, maybe I simply haven't found it? I doubt if I could remember all the options, and if I did I would probably forget them the following day anyway!
Sorry it was a long post, but better to be informed before making a purchase like this, next update will be when the finalisation of the three cameras are installed.
Many thanks for keeping up.
Regards
Dave
