- Thread starter
- #61
correction, steering relay is what I am trying to figure it out.thanks for sharing. I remember running across a posting about a vendor who made custom drag links, unfortunately I cant find it now.
I agree. If that rear overhang is as extreme as it appears in the photos then I’d recommend cutting off and positioning your own mounts. Fortunately you have another cruiser to reference! But before you do that make sure your front panels will align if you make that shift. There’s a limited amount of front to back adjustment that you can do with the fenders/grill/hood.I have both a TIG and a pulsed MIG machine that will weld aluminum, and know how to weld it.
I don't like that Aqualu doesn't have the stampings, but was thinking of adding some 'tongue depressors' to match the OE Lines.
Looking at the fit of the body mounts, I'd be tempted to cut those off before setting the tub on the frame, then tack them on, pull the tub and fully weld.
In my first 40, I had Wally in VT build me a 3/4 tub out of steel. Basically the same thing as an Aqualu tub with no ribs. Of course he made it much more stouter than OE and compared to the rusted relic I started with, I didnt miss the ribs at all.I have both a TIG and a pulsed MIG machine that will weld aluminum, and know how to weld it.
good point, I have a set of fenders I can throw on and that should gauge how far I can go forward. I should get out the tape measure and do some more checking. Its funny, the front two mounts seem to attach and align fine. The third one back was way off so I removed them with plans to reattach once I happy with the location. Over the wheel well seems about right except the welded nuts are just at the edge of the mount tab. The rear outer holes lined up but the inner two rear did not. Not sure if I mentioned but I replaced both the rear gusset and two support gussets. I doubt that is the reason why the rear of the tub is slightly overhung. The rear gussets and such bolted up with minimal effort.I agree. If that rear overhang is as extreme as it appears in the photos then I’d recommend cutting off and positioning your own mounts. Fortunately you have another cruiser to reference! But before you do that make sure your front panels will align if you make that shift. There’s a limited amount of front to back adjustment that you can do with the fenders/grill/hood.
Back to the body mounts discussion. Aside from the ones over the wheel well I should be able to shift everything forward 1/4 inch or so without much effort. I am however puzzled on the wheel well, if someone has time I would like to see what its really supposed to be like by the arch of the frame. The welded nut seems great for something on the top side to secure too but doesnt work at all for anchoring the body to the frame. Unless the welded nut is needed for something I will most likely remove it.
oh cool, thats a lot better and stronger than how its on my tub. For me, removing the welded nut isnt a big deal, it just didnt make sense why it was there. My first thought was to expand the frame mount perch to align to the tub hole. The rear overhang still has me stumped. Overall the tub is better than previous ones I have seen online in the forum.Horizontal cross bracing under the bed. I tapped the reinforced wide areas that sit over the frame mounts, countersunk the body mount and inserted a washer/nut so the mount is bolted to the body and rides on the frame. I can take more photos of this is helpful?
View attachment 3816006View attachment 3816005
You got me curious so I walked out to look and snapped a few pics. I bet those captive nuts are for you to have something to screw the body mounts into.oh cool, thats a lot better and stronger than how its on my tub. For me, removing the welded nut isnt a big deal, it just didnt make sense why it was there. My first thought was to expand the frame mount perch to align to the tub hole. The rear overhang still has me stumped. Overall the tub is better than previous ones I have seen online in the forum.
thanks for checking, looks like the welder on the line made a guess on where they shouldve been. No biggy to remove them.You got me curious so I walked out to look and snapped a few pics. I bet those captive nuts are for you to have something to screw the body mounts into.
View attachment 3816012View attachment 3816013View attachment 3816014
forum.ih8mud.com
many thanks, I was wondering how you did your install. Did they make it with the two different sizes?Just to make it a little more muddy, I really like the steering links I had made through Front Range Offroad. They cut to length and thread the desired pitch. Just another option.
It’s a bit convoluted-I have an 80 box/pit arm and mini truck steering arms. The minitruck arms are the same taper as fj60 arms, so I have a fj80 tre at the pitarm and fj60 tre at the arm. Clear as mud?many thanks, I was wondering how you did your install. Did they make it with the two different sizes?
What tie rod did you use on the pitman arm side, was it the 80 pitman arm?
The exhaust studs on an ls are like birfields on 40’s- eventually everyone has to do it. I went straight for the welder and it went pretty fast.On todays episode, I cut off the one remaining stud and then ground both nubs flat. I then drilled new holes sliding the bracket to the passenger side about 1/2 to 3/4 of an inch. I tacked the bolts too. I removed the four broken exhaust manifold bolts, I guess its an LS thing. Three of the four weren't bad to get out. The last was a true PITA, had to break out the welder and convince it to leave. I mounted both exhaust manifolds too.
He is using auto trans..The exhaust studs on an ls are like birfields on 40’s- eventually everyone has to do it. I went straight for the welder and it went pretty fast.
I’m impressed you got the rear dump headers to work. I had to use center dump and route it around the front of the oil pan. I’d love to see pics of the finished product.
True, but the problem is the output of the transfer case and the space between the frame rails- at least in my head. I wasn’t able to run the p/s exhaust backwards due this restriction. Instead I used a center dump header and routed around the sump and over to the d/s into a home made collector. Far from pretty, but it works. The only problem I have with it is the down tube off the p/s header has been self clearanced by the driveshaft. Once again- Far from pretty, but it works.He is using auto trans..
The broken studs weren't bad, two of them only took 5 minutes each. The one I had to weld was another story, had over a half an hour drilling before welding. Hopefully the exhaust manifolds will work, I have read so many articles on the forum that saw these on some ones rig and decided this was the path to take. I imagine a good exhaust shop can figure it out.The exhaust studs on an ls are like birfields on 40’s- eventually everyone has to do it. I went straight for the welder and it went pretty fast.
