I would think a faulty thermostat could get this result as well...passive cooling in non-load, not opening properly under load...
cruiserdan said:Fan clutch, 16210-66020
Fact.
alaskacruiser said:cruiserdan- RavenTai mentiones " the new one from Dan is the 3 stage Aisin, the one that was originally installed was the 2 stage (forget the manufacturer)"- are there 2 versions of the fan clutch? And what is the part # for the 3-stage clutch?
robbie said:the thermo spring on the front opens a passage when it gets too hot under the hood. This then allow the viscous fluid to flow and lock up the fan clutch.
cruiserdan said:I went down the "a bit warm path" last summer/fall and I replaced the clutch (which helped but was not enough) then I replaced the radiator (93 with 115k) All is good at the moment.
turbocruiser said:Dan, am I reading right? You replaced the 3 core brass rad with a 3 core brass rad? Was the first one leaking? Did you see some sludge? What do you attribute the better cooling to? Thanks man.![]()
turbocruiser said:Bump, I dunno if Dan saw this the first time. I'm still interested in finding out if the same rad was replaced (brass to brass)? Thanks.![]()
IdahoDoug said:Interesting comment Dan. Weighing the new and old would have been a VERY effective way of evaluating if there were deposits in there. Of course that would require drying the old one well and when your truck is dripping coolant and tranny oil and the battery tray, grille, fan, belts, misc hoses and such are laying about it's just not always in the cards.
Interesting, though. I have two used 93/94 rads that have been drying for about a year now in the corner of the garage. Guess what I'll be doing at some point, and guess who I'll be asking to weigh a new one some time soon??? Whups, don't drop those knitting needles - Turbo's going to need a new radiator soon.
DougM
