Alright 40 friends, I need help.
Do I need to cut at yellow line in order to clear bucket seats?
The plan is this: the seats will likely be Corbeau Baja SS or similar with harness and mounted to roll cage. I've done some mock up using 4x4s and plywood and don't THINK I will have clearance issue with wheel well and seat back if left square like they are but would hate to have to come back and redo once I get to cage/seats - I already hate body work. It seems that in most 40s it is required to be cut at some angle to clear bucket seats, however this tub has been stretched - this is the area between the wheel well and where it drops down near door opening. By mocking up the ergonomics of the wife's Grand Cherokee, it seems that I would be fine to leave the inner fender as is but I would love seat position input from fellow 40 owners and builders.
Here are a couple more shots of the fender wells since we're already here
It looks like less clearance than it really is, but nevertheless I was super pumped that I didn't completely screw the mounts and put the shock/reservoir line into the inner fender!
As you can tell, I have gone super highline with the inner fenders...I didn't really have an option due to the cut to fit the tires. I could have dropped them a little, but mounting would have been a pain - with the way they are now I will weld to the bottom of the tube holding the side panels.
In other news, I worked on the windshield frame. Like the rest of the body, originally I thought that it was in good shape and mostly usable. With some perspective, I was not so pumped when I dug it back out a couple week ago.
After a day of researching the price of one from AZ or SoCal, I decided to give this one a shot.
Both sides were like that, the other probably worse. For reference if you're not familiar, this is the underside of the windshield frame which rests on a rubber pad. Due to its design, it is a huge water trap and therefore a spot for corrosion.
The only pic I have during the fix is on the other side.
It is not perfect, however it will get me going for now.
It is nice to see the FJ have a bulge under the tarp again
