- Thread starter
- #121
Here's a couple more of the cage
I also started working on the front fenders. They are similar to metal tech, but I am tying them into the grill hoop. This allows a little more room for the front tire during flex since the front axle is stretched from stock and also will help support the grill hoop forward and back. The idea is to trim the front panel up and leave about 1" below the hood.
Still working on refining it. I didn't realize when I drew it in Bend Tech that the front part where the 90 degree bend meets the 27 degree bend up and over the tire that I wouldn't be able to do that in one piece because there is not enough room between bend one and two. It's either impossible to load into bender or if done from the other direction the existing bend will be limitation because it will run into the die. So two pieces it is.
