MOT, translation please.......
I might re pop a few of them, but would like to know what they say or any info I can get.
Shane
Hey Shane your eBay store is empty............I need a heather resto kit. 75.
Shane
Pic 1:
Line 1: This vehicle meets 1974 emission standards.
Line 2: Engine Type
Line 3: Engine displacement
Line 4: Engine adjustment figures
Line 5: Idling rpm
Line 6: Injection timing
Line 7: Non-load sudden acceleration pollution rate: Target 45%
Line 8: Toyota Motor Industry Co.
Pic 2:
Line 1: Caution
Line 2: This vehicle uses Toyota's genuine brake fluid 2400F DOT3
Line 3: Do not use other brake fluids
Line 4: Change: Disc brake vehicles: Every year
Line 5: Drum brake vehicles: Every inspection time
Line 6: Check/Refill: Before use/(Refill) Accordingly
Line 7: *Please refer to the service manual for details Toyota Motor Industry Co.
I personally like this one
Pic 4:
Line 1: Drive Safely
Line 2: (Let's) Buckle up
Line 3: License renewal date
Line 4: (Date) Year Month Day
NOTE: Shane, I don't think this one came factory from Toyota. But that's just a hunch.
Pic 6:
Line 1: Maintenance caution
Lines 2 & 3: 1) Always check, especially the following areas, before operating:
Line 4: Steering wheel operation
Line 5: Brake fluid level and brake operation
Line 6: Tire condition (visual) and tire pressure
Line 7: Lubrication, fuel, and coolant level and leakage
Line 8: Lighting, warning (sound) devices, windshield wipers, and gauges for proper operation
Line 9: Engine, body, and door lock operation
Lines 10-12: Please check and perform all maintenance/service according to the maintenance/service criteria listed in the maintenance booklet
Lines 13&14: Please keep the maintenance booklet in the vehicle at all times and record in it whenever manintenance work/service is performed
Lines 15&16: If you are missing the maintemance booklet, it can be acquired at a dealeship wherever this model is/was sold.
Line 17: Toyota Motor Indurstry Co.
Shane,
I don't have time to check everything, but hopefully you'll get the gist(sp) of it! ;)
I believe a 22R (or maybe it was 20R) window will fit. It doesn't have the ground glass center, but it plugged the hole on my non-USA carb.
Shane, I'd be in for a trailer tag, no need to fuss with the numbers. ;)
:confused:
Off your meds again, Dave?:D
