Monster rear heater for the kids
Downey
Brea, Calif.
I somehow ended up with the bottom floor of an FJ55 rear heater, no motor. After seeing stock fan motors cost a zillion bucks, I opted to modify a new mega motor into the floor since they cost a small fraction of the factory motors. New motor was taller, so had to cut a hole into the floor to let the motor hang down, soooo spacer tubes will be needed to get motor up off vehicle's floor panel (included). Buyer will have to drill a larger mounting hole into center of their stock heater fan blade since this shaft is slightly larger diameter, but then fan blade and upper portions of the stock heater will remain in their original locations relative to this bottom floor with it's mega motor. This item can be seen at my ebay #257031224809.
Good stuff Jim!
Those look like some tall spacer tubes. Do you know if this will still fit under a factory bench?
Don't know, never owned an FJ55. Tubes can be shortened as needed. How moch space is there now between seat and heater?????
