- Thread starter
- #41
Did some steam cleaning of the engine and trans... got the trans mounted on a stand ready for dismantling.
Is that a Galant VR4 in the background?
I always wanted to stuff a 4G63 into a late 80s 4x4 toyota pickup.. that thing would be wicked fun..
Thanks for the EPA Tag shot. It shows the engines BSFC at rated power (145hp) is 275 g/kwh.
Honestly this is a lot higher than I expected. You might have an engine that has the injection timing retarded for emissions reasons. The 3 degrees BTDC timing compares to 8 degrees BTDC for an Isuzu 4BD2T and 13 deg BTDC for an Isuzu 4BD1T.
Is this engine IDI?
Exact same EPA tag as mine.
The Fuso 4D3 is direct injected and heavily EPA regulated. IIRC Nox limits are prescribed here. This is also the exact same engine as the Euro 3 Canter, which is a fairly recently offered driveline.
The pump is a Zexel TICS. Although you set the base timing in a conventional way, the computer will actually alter the injection timing and duration of injection through the prestroke actuator. At idle, it utilizes a very steep portion of the injection cam profile, for a rapid high pressure injection. At speed, the portion of the cam having a longer, gradual ramp is used, so the injection is spread out over a longer period, reducing Nox, and the injection timing is advanced. A possible side effect may be increased fuel consumption due to a longer burn time, but I also think that the engine is timed retarded for emissions.
When I first got mine going, it smoked blue and generally acted like the timing was badly retarded. The manual has a very imprecise method that is used to check timing based looking down into the pump after removing one of the sensors. It is not accurate and I am trying to find a better method, but there is a huge amount of adjustability in the pump drive, so advancing is easy, but I suspect the timing is done through pump set-up and verifying with accuracy might be difficult without Bosch test stuff.
I advanced mine a few degrees and it now runs fine, but I think it might still be retarded as it seems a tad lazy.
The computer gets its engine position based on two sensors (redundancy) in the pump. I was surprised to find out that there is no cam, crank, flywheel or other sensor that monitors actual crankshaft position, so it would be easy to bump the timing and not have any side effect in the engine control department. I am just concerned about what advance the prestroke mechanism generates. I am pretty sure it does not advance timing at all at idle, as with the system disconnected the engine runs and sounds the same.
So as I've said many times (getting to be a broken record yet?) I'm new to the diesel thing... plenty of experience with the Otto cycle though.
Advancing the timing would have the same effect as advancing the ignition timing on a petrol car? Better response, more power/torque?
Pretty much yes.......
More advanced gives:
Crisper feel.
Louder combustion noise.
More black smoke.
Higher peak cylinder pressures.
More NOx.
More retarded gives:
Lazier feel.
Quieter and smoother.
White smoke if you go too far.
Earlier turbo spool.
It's a balancing act.....
So the natural next question is, how much power/torque can be expected from 5 degrees of timing advance?
That's a very hard question to answer. I wouldn't expect more than a few %, but you will gain fuel economy from it also.
If I can recommend something, it would be to leave your timing alone for now. Because I had to swap out the pump and the factory timing pointers are not that accurate, I am certain that mine is not timed ideally. I will mess with advancing the timing a few degrees at a time and see how it performs and yours can be the baseline. It's up to you, but I think this is the best way to go about it, that way we can really compare.
On the fuel mileage issue, you and I are both one the same wavelength. I also drive over 30K kms a year, and I had investigated the cost of a Toyota only swap with a 1HDT and it would have taken 4-5 years to amortize if I did everything myself. I was worried that in 5 years my situation would change and I would end up selling it, having spent months working to convert it for no real financial benefit. Of course the resale value would be higher, but at 30-40K kms a year, the value plummets, not to mention the fact that the truck will probably be rusty in 5 years, so I would probably not get much of a premium for it.
I have not added my receipts up but I'd bet I am in well under 3K for the conversion. That means it starts making me money in 18 months. Plus, the conversion is so easy now that everything is made that when this 80 rusts out, I will just find clean one in the south with no lockers and swap everything over. It's truly a weekend job with no wiring mods and no welding.
Based on what the Aussies tell me about the Fuso Canters, I should see well over 500 000 kms on this engine, plus it has an oil lubed pump (no silly additives), no timing belt, cast iron head (no gasket issues), etc. It's truly a medium duty truck engine.
I think if I was to do it again, I would try and simply put the 450-43LE valvebody and torque converter on the stock trans and see if it works. I may still try this if I can get my hands on a complete spare A442F as I have a spare 450-43LE trans. The higher overdrive is not that beneficial, really, and I think that the computer might work out OK even with the differing ratios. It's a long shot, and you'd be a guinea pig, but it would greatly reduce the complexity. And, in order to gain some valve cover to firewall clearance, you could oval out the holes in the trans crossmember and slide the whole thing forward, there is enough play in the driveshafts I think.
in the end, it is your time, your money and your enjoyment ... whether you make your investment back or not is irrelevant. most guys do the swap cause they want to and use the fuel mileage figures to get the permission form the boss.
<of course the boss already knows it is BS but they love yah and give you the go ahead because of the effort of the reason>
i am enjoying the thread, continue.
I forgot you had the later trans, but this is great, as we'll know how easy it is to swap the setup into a later truck, which I will probably have to do later on.
The source for an extension housing and output shaft is great, especially for the later trucks, as it saves you from buying a spare. However, I don't see a shaft listed for an A442F, only A440, same as the output housing, but they list two dimensions. can you measure yours and we will see which is correct? If I can get the parts cheap I will build up a spare 450-43LE and swap it in, to correct my front pump leak.
This just keeps getting better and better!
