Ordered the following parts from Mr. T. These are all the parts needed to convert my A343F shift linkage to A442F shift linkage:
90170-A0001 - NUT, HEXAGON
94512-00800 - WASHER, SPRING
94612-10800 - WASHER, PLATE
33723-22010 - SWIVEL, CONNECTING R
94613-10800 - WASHER,PLATE
90389-08005 - BUSHING, NO.1
90480-17177 - GROMMET
90468-14017 - CLIP
35569-60030 - ROD, TRANSMISSION CO
Also ordered the following:
35182-60010 - GASKET, EXTENSION HO
- This is a spare extension housing gasket, since only one will come in my overhaul kit and I will need two (one for each side of my spacer)
32921-60130 - TUBE, OIL COOLER INLET, NO.1
32922-60070 - TUBE, OIL COOLER OUTLET, NO.1
- These are the oil cooler tubes for the A442F, they were cut on my junkyard trans, and I didn't think the Fuso ones would have fit under the floorboard, the LC ones hug the transmission much closer.
36308-60160 - ROD SUB-ASSY, HIGH & LOW SHIFT
- This is the shift rod between the transfer case shift lever and the TC. It was broken on my junkyard transmission.
The total from a local dealer ran $204.79 with free shipping.
I ordered the transmission overhaul gasket kit with clutches from
www.wittrans.com. I also ordered a couple spare snap rings. Total was $254.67 shipped.
So this is where I'm at so far...
1999 Fuso Donor -
$1800
Towing charge - $425
Pair of Diehard Platinums - $365
Cab Recycling - $122
Chassis Recycling - $310
1st Batch of Misc AL Recycling - $307
Threaded rod, nuts, drill rod from McMaster - $38
Last batch of AL Recycling - $504
Junkyard A442F w/ Shifter and TC - $400 shipped
Shifter Parts from Mr. T - $205
AW450-43LE Overhaul Kit -
$255
Running Total - $2245
The only things left to buy to get the engine/trans in the truck are the exhaust gaskets from Mitsu so I can flip the manifold and turbo. Then I'll figure out what I need for exhaust parts, IC pipes, Radiator hoses, fuel lines, P/S hoses, A/C lines, etc. I really think I'm going to come in under $4000 easily, maybe even under $3500. Then I can sell my 1FZFE and A343F to hopefully recoup even more of the costs. If I can walk away from this conversion with less than $3k out of pocket I'll be tickled pink.
