- Thread starter
- #21
Well that's a disapointment... I wonder about the tach output from the Fuso ECU.
That might work. If you have access to an oscilloscope, check the signals put out by the FJZ80 ECM and the Fuso ECM. You are comparing voltage and frequency for a given rpm. If you are lucky they will be similar. This would actually be a better solution than the ABS sensor route.
Most of the guys running LS Chevy motors have had good luck with the Dakota Digital box. That is the route I am planning on taking. The Fuso ECU has a dedicated ground for the tach. Since the Toyota tach relies on chassis ground, I am a bit concerned as to how to hook it up. I will probably just ground the ground and hook up the tach wire to the tach + on the ECU, but I figured I would do this once I am driving it. I'm almost certain it will work with the dakota box, it acts as a signal conditioner as well as a frequency alterer. The diesel version is infinitely adjustable so you can just scroll up to the correct rate using an optical or mechanical tach.
Excellent! Pulling the harness is a PITA. I will get you those diagrams soon.
Actually it might be easier for you as you can cut the harness in the area where it goes through the floor of the cab. I wanted to keep it intact to test the engine out. You already have.
The harness is super long and must be shortened so it would save you from feeding the plugs through the floor.
Looks like a good start.
I live in the desert and air conditioning is very very nice. So my question is if you flip the exhaust like Fromage did will you be able to keep the ac compressor were it is?
I was wanting Fromage to leave the AC on his motor but he didn't.
Thanks
Correction, my Fuso did not have A/C, I have to build a custom bracket for the Toyota compressor, it's on the list... I want A/C![]()
Tell me, does your engine still have a readable EPA tag?
