Got the extension housing installed, only to find out it was spaced too far back for the park lock rod to engage into the park lock actuator. So, I took the housing off and measure the distance. I needed the rod to come back another 0.250".
I stuffed many a rag into the entire tailhousing area and then proceeded to cut the sleeve on the end of the park lock rod between the actual engagement sleeve and the welded end. I was able to split this off, and the spring had enough extension in it to push en egagement sleeve the additional 0.250" down that I needed. Unfortuately I didn't take any pictures of this.
Another thing I learned, the AW450 park lock rod is larger in diameter than the A442F rod. So, it won't engage into the A442F reciever that bolts into the extension housing. The two "fingers" are too close together. Also, that reciever is hardened steel, so don't try to bend them out, they'll just break (Ask how I know)
Also, the reciever on the A442F has a slightly smaller bolt pattern than the reciever from the AW450, so they won't just interchange. You need to elingate the holes... good luck on hardened steel. I ended up using my plasma cutter!!! But hey, it worked, and with those two mods I have park now, which is kinda a big deal to me.
Low and behold, the whole mamma jamma came together, this is one HUGE transmission!!!
