Looks like you are really making good progress. While you have the turbo out you may want to look at welding an elbow to the exhaust exit. You will see that there aren't too many options as the cast elbow just drops out. I welded a 2.5" stainless (316) tight radius weld elbow to the housing with 309 stainless filler (TIG) and it worked out slick. Then I used V bands from there on down, with 3 inch stainless. I highly recommend this way of doing it. The turbo housing is cast steel so it welds easy, and the stainless makes it look cool.
Also, if you get a 3 inch combo 45 / 180 bend (I order from mandrelbend.com) you will see that the 45 and then following 180 can be used almost as-is for the downpipe. It makes for a super stock nice looking downpipe. There are pics in my thread.
For the fuel filter I would just get a universal spin on head from Racor or some other supplier, you should be able to get something standard and cheap that is universal fit, then just mount it on the firewall and run some rubber lines.
I still don't have a wastegate for mine. Waiting for parts. It pulls better if I keep it under 10 psi, I think the engine de-fuels rather gradually to keep the boost in check. If I just floor it, it kinda falls flat on its face.
