Nope.if the tab is in the back is there any way it can be on wrong???
Glad you figured it out bud!
Clean that oil up from the top of the cylinder head and out of the rocker stand bolt hole before you put it back together....
Damn That is the nicest build I have ever seen in a personal shop. You should send that to 4WheelToyotaOwners and do a cover story on your rig. Great Job!!!!
do you know the torque specs for those bolts?
10mm bolt- 22-32 ft-lb
8mm bolt- 15-21 ft-lb
From Aug 1980 2F engine repair manual
Pub. No. 36104E
Section 3-19
Just wondering on your shop, did you put a footing down under the walls? Your in Minn. right? Must have pretty deep frost depths. I'm in Idaho and we have to have footings 24" min. Nice looking set up though and keep it coming on the build-up...
Damn Aaron, great thread. I'm coming up to live with you for a while. Need to get Poser to do the Orion in my 40. I'll sleep in the new (superfly) shop (with the refrigerator). Will wrench for food and shop! Keep up the good work!
Later,
