Your best bet on poly bushings is to use silicone grease designed for that purpose. Daystar sells theirs in 3 oz cartridges for mini grease guns. Moly will eventually breakdown the poly bushings. Be aware that this stuff is STICKY. see The Best Grease for Polyurethane Bushings
Also on the front spring, rear hanger and the rear spring front hanger, I always have to use my monster adjustable wrench to slightly bend out the hangers a bit to get the spring with bushings cleared for the install, then the torqueing process pulls them back to vertical. Without bending the sides of the hangers, it's crazy hard to get the springs in place. Depending on how strong I feel on that day, I usually employ a jack to help push the spring up into place, being careful of the bushings.
Jdc1, check what looks like the OME shackles you have on the rear spring, rear hanger. The point sticking out at the top of the side plate of the shackle is for anti-inversion. If that is the case, then that is the shackle that mounts to the front hanger of the front springs. Verify with the vendor you purchased them from.
