Did you need a spacer that @Casey E mentioned, or is just the fan all I need?
I’ve got it mounted directly to water pump and pulley. No spacer.
I assume the pulley lines up? Seems if the combo is just right no spacer needed. I’m not sure why so many of us have needed them when running without a clutch. My 2F needs the spacer if I go without clutch to line everything up.
When I bought my 68 in 1974 there was a cut in the hood and the fan shroud was MIA. My 45 has a earlier 2F that had metal fan. When the water pump started to weep I replaced with a later pump with plastic fan and fan clutch. Unless your looking to stay 100% stock would consider that upgrade. Would go the plastic fan at the very least.
I had a batch of the spacers made and offer them along with the fans and the longer mounting bolts. You can see a pic of the spacer on my Specials page.
Or here: Wanted - FJ40 Fan Spacer
Running the same setup works well.I did the same as @Living in the Past did. I upgraded to a 2f water pump and plastic fan w/clutch. It works very well.
JP
Mine is a 72 and it works great wondering how early yours is? I wasn’t aware there was a differences in engine mounting locations from early on.Mine is a 2f conversion. The FJ60 WP with fan clutch is too long to run in an early frame. All of my pulleys line up and I have also added power steering and AC.
72 as well. The radiator mounts are further back on the 72. Did you have to slide yours forward?
Now I'm all nervous. I'm also Interested in info on whether the spacer is needed on an F w/ OE water pump. Thx all, it's a wealth of knowledge around here.
Edit: Ok, I missed a couple posts there. Considering the newer pump&clutch combo
I have a 12/73 with a F motor and the old school metal radiator fan. Is there a plastic alternative? I'm not having cooling issues, it's just a bit beat up.
Thanks in advance
