Burnt spagetti wire fun! The melting shown in the two picks doest seem to go further into the harness. just whats shown in photo. If anyone is good with electrical input appreciated. The plastic clip shown in the first and last pictures was a loose and unclipped, I have no clue where its supposed to go after looking intensively. It could have totally grounded itself.
Context: I Was going to drive the rig home today the 2.5 hours and couldnt get the headlights working. In fact I found the horn, blinkers, hazards, door beep (except when WIPER relay is pulled (WTF?) aren't working either. They were working before, although the headlights would intermittently shut off. Replaced the alternator and some split wires throughout the engine bay, including the black plug by the charcoal canister, and one by the headlights. Its only after turning the rig on after 2 weeks of work regarding steering box and basic electrical repair that all 5 of these components stooped working as well.
Engine grounds and other Grounds looks good (along with one for radio etc), fusible link looks good. no fuses blown.
Ive had melted plastic around the tailight fuse since I bought the truck. The PO (total dumbass based on the state of this rig) stuck a 30 amp fuse in there and the taillights work so i didn't dig in further. Part of me thinks this happened a while ago, and maybe has gotten worse? Or the new alternator (which IS working, rig runs fine etc) somehow exacerbated the electrical problem due to proper charging? (my last alt was going out.)
Lucky I Happened to notice these wires were cooked, along with the wires going into the tail light fuse. Weirdly though,
taillights work perfectly fine BTW
QUESTIONS :
1. How does one fix this, and where can I replace this plastic piece? Im assuming cut the wires back to the unburnt section, and find something similar at O'Reillys in terms of plastic piece? Does order of green wires matter when I reinstall?
Dash is off, gauge cluster out.
2.I also have melted plastic on the fuse panel, just in the taillight fuse. Confirmed, only some of the fuses getting voltage, but some of the ones that are getting voltage dont work and some that arent getting voltage DO work. strange. Does this mean I should replace the whole fuse panel? NLA?
3. I cant seem to find it on the wiring diagram Im not great with electrical but the farm mechanic on my familys farm is helping me is passable at electrical stuff, so a good diagram is appreciated. (photo 5 is what I have found so far.)
Fresh Rebuild, rig ran and drove, just had intermittent startup issue and headlight issue that I assumed was related to the alternator going out (voltage didnt increase upon revving motor on alternator) Hard to know if my issues are interlinked and if the melted wires is the culprit.
Need to get back on the road ASAP, been up late tonight getting the dash off, troubleshooting appreciated. Can be responsive, if anyone can talk over facetime briefly that may be needed, this is a weird one is a bit beyond me.
Thanks a bunch.
Best,
Dan
QUESTIONS :
Thanks a bunch.
Best,
Dan
