Build Maytag. 1967 LPB, a daily driven survivor
SOR has a clutch and slave kit that includes the hardline. @oregon fj put his tin cups on new cylinders.
The key to keeping the original style will be the replacement of the large diameter hard line. The fittings for that line are M11, which is... odd, to say the least. Newer packages (such as the kit from SOR) use later model parts—matched master, slave, hose and hard line.
If you can get a replacement M11 hard line, then you will need to convert a brake master into a clutch master, as correct early clutch masters are almost impossible to find. I bought a new brake master from Toyota and converted it, the details are in this post - Early Master Cylinders
b3d58650-273e-458b-b48a-2d0866caf8e0-jpeg.1619963
Yeah that's the thing .I have the correcr master in hand now (converted brake MC), but can't seem to source the hard line. Thinking of just saying screw it and converting to the newer style to get it back on the road, then maybe somewhere along the line sourcing the correct line to run the original looking MC again.
You might check with @65swb45 on the early hard line, if @Rainman can't make you one. But Rainman may not have the proper M11 flare fittings to make it. Maybe you could send him your originals?
Yeah I spoke to him on the phone earlier .he told me to send the old lines and he'd see what he could do
More shenanigans today while the truck is out of commission for the clutch hydraulics.
Straightened, patched bolt holes and painted the bezel.
Installed my "auxiliary gas tank" for when i inevitably misjudge how much gas is actually left .
Also pulled the guage cluster, cleaned up all the contacts and pulled the odometer which was only rolling tenths. Followed some tutorials I found on here and disassembled, cleaned and reassembled it. I opted to zero it out, because
1. Who knows how long and for how many miles it had been broken previously.
2. It will make it much easier to track my own mileage.
3. It's not like it really matters anyway. No odo disclosure required for something this old...
Thanks for painting the bezel :cheers:
Straightened, patched bolt holes and painted the bezel. View attachment 1783563
3. It's not like it really matters anyway. No odo disclosure required for something this old... View attachment 1783560 View attachment 1783558 View attachment 1783561
Man. I need to do that to two of my trucks. How bad was it?
The odometer? Not bad at all. They're pretty simple as long as you keep the parts organized in the order you took them off you shouldn't have any problem getting it back together .
It only needs to be cleaned. There's old grease that gets gummy and prevents the gears inside from turning .
The odometer? Not bad at all. They're pretty simple as long as you keep the parts organized in the order you took them off you shouldn't have any provlepr getting it back together .
I second that, I found the same on mine, bound up with hardened grease.
One thing I noticed, be VERY careful with touching the odometer wheel numbers. The screen printing (or whatever they used) is very fragile.
20180906_141605-jpg.1783560
The higher miles or km numbers are always the problem.
They sleep more than they work :)& the grease is hard
Sometimes you can get them working again the do little way.
Lay it in the heat clean it a bit & put some spray like wd40 between the numbers.
Mine definitely needed to be pulled apart unfortunately. Some of the gears were completely locked to their spindles .
