That is correct. Last pic in post 225 above shows the different bits.
So even 25 clutch master has 11 mm fitting or both brake and clutch master uses 9 mm fittings?
Fantastic !
Still need to change the end cap fitting over right ? one is 9mm and other 11mm.
Hey guys, catching up on some killer tech here. Just to confirm, the 25 cap uses the 11mm and the later 4x variant uses the 9mm correct? Is it 11 x 1.0mm
The brake master is m9x1.0. I don't recall on the clutch master but I can check when I get home.
Only thirteen years on a rebuild. Teach me to drive this thing.View attachment 1535909
These will be coming off our 64, I will throw up on the board if there is interest?
Thx,N
Buy this part from RockAuto (here is a discount code 5078828845496240).
The tin cup swaps over. Take out the residual valve and you are good to go for a clutch.
Thought I’d update this thread. I noted in my build thread that one of the prior owners of my rig found a pair of new master cylinders on their shelf from before he decided to sell it, and brought them to me today.
My guess is that the PO must have seen this thread, as what I got were a pair of Centric cylinders, both part number 130.44730 as listed above.
Unfortunately, the cylinders inside the boxes won’t work at all. The new items look more like what Rockauto shows for FJ55 without the removable end fitting. So obviously they can’t be swapped over to work with the larger clutch lines. Worse, the end ports on both are 10mm thread, not the 9mm thread the early rigs need, so they won’t work for brakes either.
It is possible that they were misboxed, and the correct parts might be available in the future. I did ask “da google” about these, and found a review on Partsgeek.com for this same Centric number that was also said to be incorrect.
In the mean time, since my original cylinders’ bores are corroded, I need to find good replacements, and I’d like to maintain original look. Part of that will be retrofitting the tin cups, which is straightforward. And getting cylinders with the removable end cap is easy for the brakes.
But I don’t seem to be able to find a new clutch cylinder with the removable cap. The clutch cylinder bodies I’m seeing don’t look at all like the original. So should I consider the same thing as with the Centric? Buy 2 brake cylinders and modify one by removing the residual valve and swapping the end cap for the clutch?
Any other visually appropriate options?
