Who's to say it was set up right before you replaced everything? These trucks are old and tampered with.
Umm because I'm the original owner, that's how I know.
I cant tell when your joking or not. Forgive me for throwing some info in. The Marlins do seal better just like they claim. But dont have as much defelction due to them being thicker (more suface area). If its set up right, the deflection isnt an issue. The other main reason is the 80 series housing (ball ends) bend fairly easy. This also throws it all out and is noticable during a caster sweep - different cambers. Toyota actually have a special tool they use to check the axle is true.
I'm a tech for a local Toyota dealer and I haven't heard of such a tool, do you have a picture of it?
Marlins work great. The main problem is noone sets their rig up correctly. The total amount/thickness's of shims used, determins the overall knuckle preload. But where they are located (above or below) determins the knuckle/stubaxle/axles possition in relation the the seal. Meaning the same preload is acheived by putting all the shims at the top, or all at the bottom. But it raises or lower the axles possition. And if you think a few mm doesnt make much difference - it does.
... But the factory ones are thin and flimzy during install. And it would be easy to damage them and knock the ring out. ...
... The other main reason is the 80 series housing (ball ends) bend fairly easy. ...
Its a toyota SST (special service tool). Im not sure if the code is the same for the US. But did find this when I had a quick look. It explains how to set it all up correctly. Starts at page 32
http://www.lukemiller.org/toys/1985_toyota_4wd_front_axle_FSM.pdf
... And over filling the diff oil is another part. It's not ment to be filled up to the plug level.
Where do you come up with this stuff? Ofcourse you can shim it from the bottom. It's pretty much exactly the same as the description in the link.
Please report back!!
Screw the marlin seals! I put one oem in one side and marlin in the other....just for fun....Well the marlin didnt last more than a couple days. Leaking already. Time to rip it apart and put in an oem. Waste of my time.
Why does Marlin even sells these as an 80 application? Nobody has good luck with them unless part time which 90% or more of the 80's out there are not. Flame over.
