How can you tell if it's the AMP or the speaker itself? For example, my passenger side main speaker (the largest one near the floor) is crackling randomly (potentially when there is heavy bass).
Thank you!
Thank you!
Older thread, but wanted to see if anyone had a solution to this issue that doesn't require me to shell out $475 for repairing an AMP/Technology that is now 18+ years old?
Is there no way to easily swap in a JL Audio or similar amp for less $ ?
As far as I’m aware............ nope
Or you can buy a Bluetooth speaker for 150...... that’s what I did and it works until I feel like shelling out money for amp repair
hi, how did you go about wiring this up?
I've had the crackling and popping several times over the last several years in my 2004 LX, but the issue usually rights itself each time after a couple of days. This time around, it has deteriorated to the point that I'm consistently getting a split second of sound out of the speakers upon startup and then the cut-out. Bluetooth calls work fine, but no sound comes out of the stereo speakers. Is United Radio still my best option? Is it possible that I may have a fuse issue and, if so, how can I test for that?
I found out that my amp went bad from water damage (leaking sunroof) sent it out to United radio and finished in no time !Hi guys, I have a 2004 gx470 with the pop and then no sound from the radio. I am so thankful that I'm not the only one in the universe with this particular problem. Thanks so much for the info and the pics!! Forums are great for this sort of thing. I'm not sure I want to spend $450 on this old thing, but it's great to know where to go with it. Thanks again!!!!!!!
What did you use for Bluetooth?Just wanted to post my experience and add to the thread. I had the popping of the radio and intermittent sound, but Bluetooth still worked. Like others, I removed the passenger seat which made everything very easy. I removed the amp and opened it myself (which requires a Torx10?). I didn't see anything internals that looked bad, but I'm no electrician. I sent it to United Radio. You have to print out a repair form on their website. They called on same day they received it and said it was repaired. Cost $475 which included shipping back to me. I wish we knew what the defect is. I doubt the cost is anywhere close to what they charge, but of course, we are paying for their expertise. Either way, it works great for now and hopefully at least another 10 years.
862800WA40 | AMPLIFIER ASSY, STEREO COMPONENT | 86280 | URJ201 AUDIO(FOR OVERSEAS MARKET)-EMV + DVD + AM/FM + *MAR 19SPEAKER | 1 | 01.2012 - 09.2015 |
If you need a replacement amp, I have one for sale.does anyone know ... why not? Why isn't there an aftermarket replacement option?
I was quoted $675 from United. part #86280-0WA40
Retrieved below from partsouq.com
862800WA40 AMPLIFIER ASSY, STEREO COMPONENT 86280 URJ201 AUDIO(FOR OVERSEAS MARKET)-EMV + DVD + AM/FM + *MAR 19SPEAKER 1 01.2012 - 09.2015
I took my complete system out and replaced it with an upgraded audio system. These are just parts in a closet.so do you fix your own or buy someone else's that may break and need fixing later itself?
