Wow! Welcome back! A new life at 210k. Only in a cruiser...
Looking forward to this build. If the other projects I've seen @Boston Mangler build are any indication, there's going to be some really cool things to come. The rig already has some unique things that make it pretty special.
Subscribed...
Where did you find the printed manuals? Looking for a 2011
Also, you need to call some folks back.
Also, you need to call some folks back.![]()
Grom installed and it was suprisingly easy
Plug and Play as advertised (rare)
Quick function check shows the 2 main things I want and need working perfectly
45 minute install, id rate it one Banana
I followed this video for install notes:
i wish i had the skillz for this
Well, good news and bad news.
I was able to get both of my rear door lock actuators replaced, and it was easy peazy.
Bad news, theyre identical part # to the ones i pulled out, which LOOKED to be in perfect condition. no corrosion, muck built up, looked brand new etc... Will see how long it lasts.
I would definitely rate this task as a one Banana
Other write ups on here detail a pretty involved process of removing a bunch of stuff and this that and the other.
PROTIP: Remove door panel, remove 3 screws holding actuator into door, rotate it counterclockwise and remove it through hole while everything is still attached. Place new one beside it, swap cables over, return to position clockwise, and reinstall 3 screws.
Just Make sure door latch lines up with fork while rotating back in place, and Bob is your uncle.
I am a big clumsy oaf with sasquatch hands and didnt have any issues.
Observation: Before replacing them, i wouldnt get a chirp confirming the doors were locked (because they werent), now i do and all 4 are functioning like they should. Woohoo!
I'd be curious if spraying electronics cleaner on the actuator motors would be a fix in itself?
I find many motors at higher mileage are susceptible to brush graphite/carbon buildup. My experience is that cleaning the motors really wakes them up to deliver the torque necessary to do their job. The difference shows immediately on a bench test and I'd be curious if the actuator you took out could be experimented with?
HVAC Blower motor replacement next.
It’s shot and causes some crazy vibrations when I put the fan on.
Not even done and this is at least a 2job due to cirque de sole level contortion required to access it from under glove box.
Got the old one out and LOTS of play in the bearings, so that’s a win!
Upon first inspection of the truck before
picking it up, I thought it was AC compressor.
$150 vs $1500
Hopes and prayers this is the fix
While you're in there, 100% do this, too. HVAC Recirc Door - https://forum.ih8mud.com/threads/hvac-recirc-door.1333718/post-15386648
New blower motor finally arrived
Gonna try to recruit a buddy with smaller hands to get that sumbitch back in there.
Comparing the wheel play in the 2 makes me confident this was my issue. Old one is super sloppy, new one, zero play.![]()
