Builds Manglers "Flying Egg" Resto-Build (4 Viewers)
San Diego
Website
youtube.com
Guess who's back? Back again?
After a long hiatus, i am now back in the Cruiser game.
Some of you that have been around awhile (@KLF from our YT days) might know me from threads of stupid mods back in the day that ended up working great and getting stickied, such as:
-Retrofitting 80 series Elockers into an FJ60
-First US install of an LRA aux tank into an 80 using all OEM parts from OZ including overhead factory aux tank fuel gauge and OEM sub tank button
-Racing an 80 in the Baja1000 and giving that @cruiseroutfit fella a kick in the pants to start racing...
Anyway... After a couple years of searching for "THE ONE", I finally found it, oddly, from a long time friend and fellow Cruisernerd and got it home...
2010
210k On The Clock
Bone Stock
Cool Box Fridge Thing
Immaculate interior to the point its kinda sketchy, not even the usual tears in seats or anything at all
Not a speck of rust anywhere underneath, flawless
Radiator was replaced at dealer as preventive maintenance
Its one of the cleanest i've seen, but needs some obvious TLC (see what i did there?) due to the mileage.
I will be covering the restoration and mods here, but the vibe of the "build" portion will be following the legendary @TeCKis300 keep it light and stealthy mantra
Immediate "Needs" to figure out what all these fancy weird buttons and options do
Immediate "Fixes" are LCAs, which will snowball into UCA, which will snowball into suspension, which will snowball into replacing every single control arm front and rear, and since i am in there, i might as well DBA all the brakes, etc... due to mileage. :)
Also need to replace the door lock actuators in the rear, Do all at once?
Immediate "Mods" will be Slee Step Sliders
Without further ado, here are some obligatory first day poser pics 🖕😂🖕
MY PART # LIST THAT WILL BE UPDATED AS I GO
PartPart #Price (Olath Toyota)
Lower Control Arm Right48068-60030303.85
Lower Control Arm Left48069-60030303.85
Upper Control Arm Right48610-60060288.1
Upper Control Arm Left48630-60030288.1
Rear Upper Control Arm Left48710-60150143.95
Rear Upper Control Arm Right48710-60140143.95
Rear Lower Control Arm Same48720-60070184.03
Front Stabilzer Bar Link Left48810-60060105.6
Front Stabilzer Bar Link Right48820-6008291.44
Trackbar48740-60150159.92
Cam Adjuster (2)48.84
Cam Adjuster (2)48190-0C020 (2)65.5
Stabilizer Bushing (Sway Bar) Rear (2)48815-6022121.98
Stabilizer Bushing (Sway Bar) Front (2)48815-6026025.97
Stabilizer Cushion (Sway Bar) Rear (2)48817-6001010.16
DBA Front Rotors (fronts are different for 2016+) (2)DBA4722S257.18
DBA Rear Rotors (2)DBA-42723S204.82
Hawk LTS Pads FrontHWKHB589Y.704121.00
Hawk LTS Pads RearHWKHB590Y.68289.00
HVAC Blower Motor
87103-60481
143.94
Rear Driver Door Lock Actuator
DLT055 (Aisin)
116.79
Rear Driver Door Pass Actuator
DLT023
130.79
Front Wheel Bearing Complete Assembly (From Cruiser Outfitters)
FAHUB200KITJP
277.50
OEM CV Axles
43430-60071
314.54
OEM Power Steering Pump44310-60490311.37
OEM Alternator27060-38050498.24
OEM Waterpump1610009491147.09
OEM Waterpump Gasket16271-3802011.08
OEM Serpentine Belt90916-A203368.72
OEM Belt Tensioner Assembly16620-0S01280.19
OEM Drive Belt Pulley16603-3801296.51
OEM Fan Clutch16210-38071155.33
OEM Fluid Coupling Bracket16380-0S010219.14
OEM Driveshaft Ujoints04371-6007065.40
OEM AC Compressor Clutch88410-6A090151.39
OEM Thermostat (CHECK SPECIFIC MODEL, VARIOUS OPTIONS)16031-0S01052.37
OEM Thermostat Gasket16326-700207.50
OEM AC COMPRESSOR CLUTCH884410-6A090152.31
OEM 2013+ OEM Headlight Right81145-60F50600.46
OEM 2013+ OEM Headlight Left81185-60F50600.46
OEM HID Ballast (need 2)81107-60F10189.25 each
OEM HID Low Beam Bulbs (need 2)90981-20024152.82 each
I still remember you wheeling the piss out of that leased white Taco. Wow that was a long time ago...
Yes sir…
Remember bringing it to dealer and told them the leaf springs bent “on a pothole” and they warrantied it all.. Man I did some dumb things 😂
Hope all is well sir! Is that Karl fella still around?
Ha I haven't seen or heard from Karl for at least 15 years. Last I knew he was working on installing a Supra engine in that white 4Runner, but no Idea if he ever got it done.
I also wonder where Charlie Horn is these days.
Welcome to the white Cruiser club.
If you happen to have Karl’s phone # please DM me…
I’m pretty sure Charlie is likely wandering around in the woods somewhere looking for fungus
You should put a PowerBrake big brake kit so it can handle all the Tacos you’re going to load up with.
Will be doing brake upgrade for sure
But now…. I’m going to get tacos since you said tacos and @KLF mentioned tacos and now I need tacos
Went through my contacts... Nothin, sorry. Maybe try FB or LinkedIn, neither of which I use.
I don’t have either. Oh well…. All good
welcome back
get rid of that ghetto tint
Thanks and No
I’m a Ginger and have pretty extensive skin cancer from years of working outside. Next surgery is in 2 weeks.
Tint will stay, and likely be redone even darker to protect my pretty face 😜
wheels gone
Welcome back indeed. I just saw your post in the pic thread and had a “whoa” moment from a name I hadn’t seen in a long time.
Finally moved from the moonglow 80 to the white 200 club myself.
Enjoy the ride !
If anyone wants these for FREE.99, i need to get rid of these, zero use for them, and already have 4 sets of various wheels laying around.
Wifey doesnt share in the same enthusiasm in wheel collection activities
Did i mention FREE?
Located in San Diego near the 5/52 freeways, pickup ONLY
Possible deliver within 15 minute radius if you buy Tacos
Dang, I wish you were closer those would look amazing on my 21 HE!
Good luck on the Giveaway!
Looking forward to this build. If the other projects I've seen @Boston Mangler build are any indication, there's going to be some really cool things to come. The rig already has some unique things that make it pretty special.
Subscribed...
