Making stock wheels wider fj55
fj55-100
This started as a what wheel do i want , I have old school indy slot mags on it now (cause Im old). and had a set of western mag wheels on before that . and have run the walker evans beadlocks off my trail rig (86 $runner 3.4 supercharged , caged ,bla bla bla ect) . but cant seem to find a wheel that i like or that will fit the backspacing i need with disc on the front , using the 92-95 s13wb calipers left little room for a 35 inch tire . all modern wheels just dont do it for me . after looking at countless pictures of fj55s i really like the stock wheel with the hub caps ,but they are only 6 1/2 wide and wont run 35 12.50 bfg tires ,and the back spacing needs fixing . Used the search button all over the interweb and mabey 2 or 3 companys still widen wheels , when i inquired on a cost for 5 wheels it was more than i paid for my piggie . So putting 2900$ in tires and stock looking wheels is not in my budget .
So now comes the LOW TECH approach . i am not afraid of making my own parts . so ....
Step one i need 5 stock wheels for the centers and the hub cap clips .Toyota pn 42601-60072 fits the bill at 98$ cost each
Step two outer rings . Speedway sells wheel shells in a few widths for dirt track racing . so 8 inch was the magic depth to hold a 35x12.50 15 . 38$ each
Step three ,now the LOW TECH not having a gap lathe ,my lathe only will swing 12 inches . i used my brake lathe to cut out the centers to a press fit in the shells .
step four, made up a jig to center the center in the shells so i could repeat the process as many times as needed , welded together with more weld than the oem ones came with .
Spun the bare wheel on my road force tire ballencer and was pleased to see the run out was less than some cars i see in the shop everyday .
Step five (pending ) will send out to the powder coater to make a lasting finish ..
I have two left to do this to so i will fill in the missing pictures as it happens
pictures to follow
riveted wheels are to large to turn down and leave someting to weld to
So you are using brand new outer space and brand new inners. What back spacing? Someone needs to mass produced these. Every series landcruiser would love the availability:).
back spacing , for my needs is 3.25 , If they were produced somewhere that didnt include selling a kidney . i would have went that route. I lack the skill to make more than one at a time . for me it takes about 2 hrs with a dial indicator to set up the weld for each one. And still i think there has to be is a better way.
