welp. sold my 37s. ordered new 35s km2s. going to be focused on lowering the truck down to about 25" of frame clearance. down from 29" just the tires alone will get me closer to that goal. and with my new springs and working the front springs. itll be very doable!
Here's the springs. The non arched set is from a 2013 TRD Tacoma. Was thinking of pulling the bushings out of it and using them in my leaf pack so I don't have the polyurethane squeak. and my brother is going to be using the overload from it.
Here's how the truck sits currently until Friday or Monday. depending on when the wheels come in.
Lowering my truck down is going to require me to relocate the steering stabilizer and get a different oil pan from a 2wd 3vz ( rear sump )
Here's a picture of the steering stabilizer issue. if I pulled a leaf spring in the front, which I plan to do. it would basically bottom out on the oil pan over every obstacle. currently, theres about 2-3" from the pan, which still sucks. So I'm going to fab up some new brackets, cut the ones off my axle and put them on the passenger frame rail and route the stabilizer to my steering arm, not the drag link.
Top part of the steering stabilizer w/ a dent in it.
bottom part of the oil pan with a mark on it.
All in all, this should make this truck a helluva lot more fun to drive/wheel. ill keep everybody posted. I'm swapping the clutch out this weekend, hopefully.
