Maintenance Question
VA
I know I am taking a chance on getting ridiculed but I am hoping I can get some guidance. Just purchased a '23 GX460 with 24K miles. My question is regarding the gear oil and transfer case oil. I have decided to use 5W-30 in the engine. I know what the manual says for the gear and transfer case oil but what do you use? I want to protect my "investment" and don't care about fuel economy (if I did, I sure would not have purchased a V8). It seems some use 75W-90 for all three boxes. Some use Red Line for the transfer case. Anyways, I'd like your opinion. Oh, I did get that small filter to replace the foam one on the secondary air box. Any advice, I'm all eyes and ears.
Likely to hear full spectrum of recommendations
I wouldn't think the 5W-30 would cause any issues.. IIRC...others have previously posted an option in other markets.
I do 0W-20 Amsoil on mine. I also use Amsoil gear oil for the front and rear diff..but the OEM 75W unicorn piss in the center diff. :-)
I haven't used it myself but Revenol has a straight 75W for far cheaper than OEM
I just did a full fluid replacement at 45k miles. Toyota coolant, trans fluid, and gear oil for the transfer case. F/R diffs, used redline. Similar logic to protect my Nori.
I use Ravenol in all 3 boxes. I get the kit with all the oil from Blau Parts.
Highly doubt that you will get ridiculed for asking, and good on you for doing the maintenance that many overlook.
What weights are you using ?
I have the dealer do it, and use that as an opportunity to get a second set of eyes on my chassis.
I use recommended weight. If it was a steel block I would probably run 10w30
The diffs and T-cases in these rigs most definitely do not need any kind of special or expensive fluid. IMO, what's more important is the frequency of the fluid change rather than the type of fluid. After all, the diffs don't have any kind of a filter in them, just a magnet for metal parts.
My TC gets Mobil Delvac 75w90. It is a great synthetic gear oil. It's commonly used in HD trucks and it lacks a limited slip additive (and is one of the only synthetic gear oils that doesn't include it). Oh - it's cheap too. It runs very quiet in the transfer case, including in the cold.
The diffs on these rigs are even less picky. Prior to upgrading diffs on my GX, I was running cheap Valvoline conventional 80w90 in the front and rear, but changing it yearly (as I do lots of creek crossings and submerge the diffs - and there would be evidence of some water in the diffs at each yearly change).
In June I removed both differentials in order to swap them out with upgraded diffs from ECGS. Here is the OEM 3rd member with 190K on it (with 55K of those miles being mine). Perfect condition in every way, with even the OEM paint markings still being visible. The rig was used hard over my 55K, including lots of wheeling and towing.
Not sure offhand which diff fluids match at similar levels the stock additive package for 75W used in TC.
Here is a Blackstone report on the stock 75W TC fluid
319983d1543609569-redline-75w85-gl5-gear-oil-would-safe-use-my-transfer-case-toyota-transfer-case-fluid-jpg
Here is one for the 75W Ravenol
319986d1543610045-redline-75w85-gl5-gear-oil-would-safe-use-my-transfer-case-ravenol-fluid-jpg
For engine oil, I use the factory 0W-20. I use synthetic and it's typically Costco. On the initial change of the diffs and TC, I used the Toyota stuff. On the last change I used Valvoline 75W-90 synthetic for all three. Didn't notice a difference except for it costing half as much. For the radiator and transmission I use Toyota stuff.
Vavoline MaxLife is a great ATF that is about half the cost of Toyota WS. And it's a full synthetic fluid, which WS is not. But, I'd only use MaxLife if you are doing a full exchange where you are completely replacing all of the fluid. Otherwise, just use WS to prevent the two fluids from mixing.
The only Toyota-branded fluids I use are:
1) Pink SLL coolant. It's basically the same price as aftermarket fluids and matches the fill that was in my GX when I got it, and the factory battery and engine coolant in our Highlander. Being that it's very hard to get all the coolant out at home when DIYing a coolant exchange, I just use the same Toyota stuff to avoid the potential for two different coolant formulations to mix.
2. Toyota Pink FIPG seal packing. This stuff is super expensive (like 3-4X the price of Permatex) but is awesome. It sets up in <1 hour as opposed to normal FIPG which usually requires 24+ hours.
I've heard some differing options on WS versus Maxlife
I seen more than a few state WS is likely a Group III and that Maxlife is a Group IV but built on a Group III base oil so kind of a mix
I'm thinking about all the Toyota/Lexus products that go a quarter million/half million miles plus on factory fluids.
So why not just stay with factory fluids?
When my wife and got rid of our 100 series Landcruisers (she had one and I had mine), she had over 280k miles, mine had over 260k miles.
Both ran strong enough to still travel across the U.S. with not an issue.
We got rid of them because the interior was worn, torn, and pretty ugly, same for the paint. The clear coat was all peeled off and the paint was in bad shape. But mechanically they were fine!
So the moral to the story is, how long do you plan on keeping your rig?
Do you really plan on keeping it over a quarter million miles, even when the paint and interior gets ugly? If not, don't worry about your fluids. Just stay with the factory specs and don't over think it. When you start getting into uber high mileage, I'm can almost guarantee you it won't be your diff's that will be making you want to trade it in.
Three reasons:
1. Factory fluids can be hard to find. I live in a rural area where most cars are domestics. The nearest Toyota dealer is 45 minutes away. That's fine for fluids like coolant that I change every 50K (3 to 5 years) but would be a big inconvenience for oil (2-3X a year), diffs (1X per year), and the TC case (about every 2 years).
2. Some of the OEM fluids are IMO an inferior product relative to the aftermarket. That's Toyota WS :). As evidenced by many confirmed reports of GX460 transmission failures on the factory fill using WS.
3. Some of the Toyota fluids are quite expensive relative to the aftermarket alternative (WS and gear oil). For gear oil in particular, the main failure mode for a rig that gets wheeled is contamination (water/dirt) rather than breakdown, which is why I change mine yearly. Toyota 75w85 is about $40/quart; Valvoline 80w90 is about $7/quart. So, the annual change for both diffs would cost $200 using Toyota fluids, relative to $35 using Valvoline. The Toyota fluids may be "better" if you are running let's say a 4-year/50K change interval, but for my 12-month interval, it would most certainly be a waste of $165*.
FYI I re-did my leather seats, cleaned up the interior, and put in a new dash 1.5 years ago. When the clear coat peels I'll get the rig re-painted :).
*I'm now running Lucas 85W140 in the diffs per the warranty requirements of ECGS. When the warranty is out I'll go back to a lighter fluid. However the Lucas is only $9/quart at my local farm store.
I am just struggling with the Transfer case 75W. Ive always used Amsoil oil and gear and ATF fluids. They don't have a compatible 75W but Red Line and Ravenal do.
IMO: Insufficient stock cooling compounded by ambiguous/or lacking AT service advice from Lexus dealers (even though some maintenance is suggested at 60K miles) has contributed to a significant number of the reported AT failures over the years. IMO: Lexus didn’t pivot to the realization that many were using these vehicle for more than mall duty until well into…. half-way through Gen 2. Dan(GXOR) made them see the light.
I picked up my ‘12 in ‘17 and even things like AT coolers or AT fluid changes were outlier conversations in those recent years.
The 75W spec in lieu of 75W90 is probably for fuel economy purposes. Mine runs just fine and very quiet - including in -10F weather - with the $12/quart Delvac 75W90 synthetic in it. Many folks widely used 75W90 in these TCs, and there have been reports of dealers using it too in lieu of the overpriced Toyota fluids. The TC is the one place I would splurge for synthetic fluid (I've had conventional in mine before and it is definitely a bit quieter with synthetic), but I wouldn't worry about matching the OEM Toyota fluids weights exactly.
I agree with Rednexus. I have used synthetic 75w90, both mobil1 and valvoline for the last 70k in the diffs and tc with no issues. I know it’s overkill, but I change them every 25k. I use my rig pretty hard, with multiple off-road trips every year.
One last maintenance question. The seats in a premium plus are not leather, right? Only the luxury has aniline. What do you treat them with? I used leatherique on my ‘07 GX470.
Thank y’all for all your advice.
