What's your Airbag (suspension) Maintenance?
Got a 2015 Luxury with air suspension. What do you guys do to keep your airbags fit and proper?
Can you spray them with something to keep the rubber supple?
I just removed them and added a 3" suspension lift! :D
Seriously, I don't believe there is any maintenance required.
If it doesn't have it in your owners manual, then I wouldn't worry about it.
Although that should not be taken at face value, because the manual states that we don't need to service the transmission, but as many on this forum state, including myself, the trans should be flushed. The argument is: how often?? Some say 30k miles, some 60k, some say 100k.
But to the point, put a trans flush in on your maintenance calendar. Just decide how many miles you want it to be.
2014 here and haven't done anything yet. I am running a washer trick to lift them for the last 7-8 months and haven't had an issue. I am thinking about switching to Airbag Man extended bags if I have any issues.
@r2m did you mention before that your auto leveling headlights threw some codes or something when you removed yours?
Yeah, my AFS light is always on. Something with the AFS at the axle. Don't know which axle or what the issue is.
I've tried adjusting them and finally just removed the rear ones. Don't know which corner, if it's the front or the rear or even if it's just one.
After so many years with the light being on, I never see it any longer.
That sucks. I actually like the airbags so I'll probably just keep them and upgrade them if needed. I like knowing my lights are not blinding people too so I don't want to lose the auto leveling there either.
