Maintenance Question (7 Viewers)
VA
I know I am taking a chance on getting ridiculed but I am hoping I can get some guidance. Just purchased a '23 GX460 with 24K miles. My question is regarding the gear oil and transfer case oil. I have decided to use 5W-30 in the engine. I know what the manual says for the gear and transfer case oil but what do you use? I want to protect my "investment" and don't care about fuel economy (if I did, I sure would not have purchased a V8). It seems some use 75W-90 for all three boxes. Some use Red Line for the transfer case. Anyways, I'd like your opinion. Oh, I did get that small filter to replace the foam one on the secondary air box. Any advice, I'm all eyes and ears.
Likely to hear full spectrum of recommendations
I wouldn't think the 5W-30 would cause any issues.. IIRC...others have previously posted an option in other markets.
I do 0W-20 Amsoil on mine. I also use Amsoil gear oil for the front and rear diff..but the OEM 75W unicorn piss in the center diff. :-)
I haven't used it myself but Revenol has a straight 75W for far cheaper than OEM
I just did a full fluid replacement at 45k miles. Toyota coolant, trans fluid, and gear oil for the transfer case. F/R diffs, used redline. Similar logic to protect my Nori.
What weights are you using ?
I have the dealer do it, and use that as an opportunity to get a second set of eyes on my chassis.
I use recommended weight. If it was a steel block I would probably run 10w30
The diffs and T-cases in these rigs most definitely do not need any kind of special or expensive fluid. IMO, what's more important is the frequency of the fluid change rather than the type of fluid. After all, the diffs don't have any kind of a filter in them, just a magnet for metal parts.
My TC gets Mobil Delvac 75w90. It is a great synthetic gear oil. It's commonly used in HD trucks and it lacks a limited slip additive (and is one of the only synthetic gear oils that doesn't include it). Oh - it's cheap too. It runs very quiet in the transfer case, including in the cold.
The diffs on these rigs are even less picky. Prior to upgrading diffs on my GX, I was running cheap Valvoline conventional 80w90 in the front and rear, but changing it yearly (as I do lots of creek crossings and submerge the diffs - and there would be evidence of some water in the diffs at each yearly change).
In June I removed both differentials in order to swap them out with upgraded diffs from ECGS. Here is the OEM 3rd member with 190K on it (with 55K of those miles being mine). Perfect condition in every way, with even the OEM paint markings still being visible. The rig was used hard over my 55K, including lots of wheeling and towing.
