- Thread starter
- #61
Yes, I believe it would be deactivated by holding it down for three seconds when not moving. After researching a bit more, sounds like general consensus is to leave on as it shouldn't ever actually activate with proper set up. My neighbor recommended it off, which seemed counterintuitive so started researching. There was a manufacture that recommended shutting it off, but I have no idea the dynamics behind why.
was reading some posts here: F150 sway control setting ON or OFF - Jayco RV Owners Forum - https://www.jaycoowners.com/forums/f37/f150-sway-control-setting-on-or-off-70994.html
Gotcha. Yeah, I've heard off-hand comments about turning it off too and it's very gray area. I chalk it up to unintended consequences of setups with bad fundamental adjustment of the WD hitch to begin with. The thing about electronic sway control is that it typically applies single brakes to bring TV yaw under control. The act of braking in certain situations can sometimes perturb or escalate trailer sway. Because a component of sway is that the trailer has excess momentum upon the TV, and by braking the TV more, can sometimes exacerbate the sway situation. Which is why you've probably heard that in a sway event, proper reaction is to manually brake the trailer and not the TV.
That said, the above is a very narrow situation, and with proper rig and mechanical WD setup, shouldn't happen to being with. TV electronic sway control has benefits in a broader set of situations like understeer, oversteer, cross winds where it can do things to correct the attitude of the rig in ways that the driver cannot.
Bottom line IMO, is that it should be left on. But also that due diligence should be exercised to properly setup the rest of the rig. If the rig doesn't feel stable to begin with, then it's not properly setup, and no amount of TV electronic sway control will be a useful safety net.
