The oem 2016+ front coils appear to be 14.5mm thick and 8 coils tall (including the mini coil at the top but not including the flat one that is sort of doubled at the bottom).
Concur on the 8 coils. What is the inner diameter (size of the doughnut hole) or outer diameter (from outside edge to outside edge)? With one of those we can figure the theoretical spring rate.The oem 2016+ front coils appear to be 14.5mm thick and 8 coils tall (including the mini coil at the top but not including the flat one that is sort of doubled at the bottom).
Picture earlier in thread on page 1. The oem passenger has 6.25 coils
12.67mm, 149.7mm inner diameter
73 lb/in
Really?
ok. so that makes thisOem rear driver
12.67mm, 175mm outer, 5.25 wraps
92 lb/in
I would think the same thing but the brake lines seemed to limit the articulation more on the passenger side than the driver’s side. Then the interference of the upper link to the gas tank is next. Driver’s side seemed to articulate more easily (each side worked on with the lower portion of shock removed).I've always wondered why the passenger side coil is longer on the factory setup. My current thinking is that the passenger side has more droop capacity because of the panhard geometry. Combined with minor weight differences with the gas tank on that side.
If memory serves, the passenger rear is not only longer, it actually has a thinner coil. In other words the driver rear has 5 coils at whatever the thickness of the wire is…the passenger rear has 6 coils but has a thinner wire.ok. so that makes this
Driver - 12.67mm, 168.3mm outer (143mm inner), 5.25 wraps - 105 in /lb
Pass - 12.67, 168.3mm outer (143mm inner), 6.25 wraps - 82 in / lb
So now the driver is exactly the same measured and theoretical at 105 in / lb
Not sure how springs combine, but if it's linearly than the mean of above is 93.5 in / lb between the two.
You are correct. I’m at about 12.45 on most of the passenger coilIf memory serves, the passenger rear is not only longer, it actually has a thinner coil. In other words the driver rear has 5 coils at whatever the thickness of the wire is…the passenger rear has 6 coils but has a thinner wire.
Pass coil updated to new coil thicknessok. so that makes this
You could be right. Although I think the shock really limits a lot of droop on either side. W/o them attached, it was crazy how much more articulation I could get and has me planning on moving the lower shock up to that next hole with a large grade 8 bolt through it as some have already done. Then I’ll adjust the bumpstop down accordingly.I may have it backwards. Will have to noodle on it a bit more.![]()
I think 45" tires aught to practically do it.I’d love to just know how to eliminate the high speed low mode!
When was the last time your accumulators were replaced?Well, over the weekend, I had the chance to do some more higher speed miles on the Interstate. And when it drops into the faster speed “low” mode, I did experience a more bouncy ride. I switched from sport to normal and to comfort, just trying to see how the suspension was dealing with it in every mode and it was better in Normal and comfort. I would usually use Sport on the interstate, and it felt better after cycling through the other modes when returning to sport mode but still a noticeable difference. Especially noticeable as a difference between the spring rates front to back. So when going over seams, the vehicle seemed to react different front to rear. Front was softer than the rear and the rear seemed under damped.
I have the Westcott front coil spacer and preload spacer that @TeCKis300 recommended on order. We’ll see if that helps match front to rear.
Or ideally, I’d love to just know how to eliminate the high speed low mode! Anyone know if there is someone we could send that little ECU to in order to eliminate that specific function?
Never replaced accumulators, which is in the back of my mind @ 218k miles.When was the last time your accumulators were replaced?
What size coil spacers are you running?
I had a bouncy ride that slowly snuck up on me when the truck was about 10 years old (less than 100k miles). Cost like $600 to replace accumulators. Fixed the bouncy ride. Not a difficult job.Never replaced accumulators, which is in the back of my mind @ 218k miles.
And the size of coil spacer I posted up therebut it’s a 50mm. Admittedly more than anyone else so far on this 2168 coil. However the total height is equal to the OEM passenger coil.
