A while back low fuel indicator light came on and stayed on. Gauge worked fine, but low fuel indicator light was on from full to empty and everywhere in between.
So I check around and some knowledgeable folks tell me it's a bad sensor in the tank. Of course this tiny little sensor is part of the entire fuel float level / gauge sending unit. So I figure OK - I'll replace it and that PM fuel sock item that I've been reading so much about.
Couple of hundred bucks later I get all the new parts from Cdan for the job and dig in. Pull the seats, the carpet and do a nice clean job getting everything out and back in - except the fuel sock - more on that in a moment. New fuel tank gauge sending unit, electrical connection screws, banjo fitting gaskets, fuel pump housing cover gasket. Button it all up and sure enough the low fuel indicator light is off and the gauge is working.
One week later the low fuel indicator light came back on full time and has stayed that way since. Anybody else have this experience or any ideas?
And then there's the infamous fuel sock. The part that I got didn't fit. It wouldn't go on no matter how hard I tried. The fitting was too large for the inside diameter of the opening on the new sock. No way was it going on. Too small. The old one was clean as a whistle other than some discoloration so it went back on and I threw the new POS away.
FYI I triple checked the fuel sock part number before and after the fact just for the record. Moral of that story on the fuel sock is - I wouldn't worry about it unless it's screwed up. It's a lot of work to get at just to have to throw the new one away.
