OK, so I've been putting off replacing all my bleeder valves for some time now.
Never had any problems with my brakes, but figured I should get it done before my next brake service.
I got all four caliper valves from the dealer, but went with a Speed Bleeder for the LSPV
After hitting the beach trails over the Winter, the old ones were pretty seized up, so I had to break out the torch for a little quick heat and was able to get them loose
Thing is, I didn't have someone on hand to hold the pedal down, so it they most likely took in some air.
The new caliper valves went on fine, but the speed bleeder came up about 2mm too short and wouldn't seat properly before bottoming out
So I just took the old one, soaked it in some brake cleaner, ran a piece of wire through it and blew it out with compressed air.
Popped it back in and it I was good to go.
Did the usual 2 man bleed starting with the calipers furthest from the master and finally did the LSPV.
All was good until this morning when I noticed the pedal getting hard after a quick stop
If I drive for a bit and do a hard stop, it felt fine, but if I try to stop immediately after that, the pedal would get stiff and I wouldn't have any power brakes
So I came back to the shop, but I'm the only one here, so I used a vacuum bleeder.
Did the usual rounds for each caliper and finally the LSPV, but didn't see any visible bubbles in the line.
Then our shop manager showed up and I had him pump the brakes for another 2-man bleed.
We did it both with the engine off and then again with the engine running.
Good flow from each valve and again, no bubbles in the line.
Checked each wheel individually and each one holds and releases just fine.
Took her out for a test drive, but the pedal still gets stiff after the first hard stop
Is there sumthin I'm missing here?
