Thought you got hit with the ban stick . . . glad you survived.
Is this the full BOM for front and rear? $1500 ish . . .
AHC Long Travel
Panhard Drop Bracket $103.50
Panhard Correction Kits - https://eimkeith.com/buystuff/pck/#200
Adj Panhard bar $240
Adjustable Rear Panhard Bar Suited For Toyota 200 Series Land Cruiser / Lexus LX570 - https://ironman4x4america.com/adjustable-rear-panhard-bar-suited-for-toyota-200-series-land-cruiser-lexus-lx570/?sku=PANHARD016&gclid=CjwKCAiA85efBhBbEiwAD7oLQGuQDHLknbEOkJfYD4i8Ol-ixOEFwBSt3ArVDr7-6igGV7h_Dt2AdxoCQQgQAvD_BwE
Rear coil spacer $175 (kit prorate)
Land Cruiser (200 Series) Preload Collar Lift Kit - Westcott Designs - https://westcottdesigns.net/product/land-cruiser-200-series-preload-collar-lift-kit/
Rear shock adapter $324
https://www.ee-offroading.com
Front spacer (20mm) $75AUD
Toyota LandCruiser 200 20mm Strut Top Spacer - PSRLAN-018 - PSR Quality Offroad 4X4 & Racing Products - https://www.performancesuspension.com.au/toyota-landcruiser-200-20mm-strut-top-spacer
Front Preload collar $250 (kit prorate)
Extended Brake lines front $75?
Extended brake lines rear $75?
Diff breather extension (free)
Extended Bumpstops $200
Overlanding Gear | Perryparts - https://www.perryparts.com/shop
What's missing? How much brake line extension is required?
sadly I'm just feeding on the crumbs of those who can bake bread on this one . . .long travel or lift or both?
In my mind the perfect scenario is useable travel without lift. So front OEM spacer, rear shock relocation, rear bump stop spacer and extended rear brake lines. Couple that with a sensor adjustment to hit close to factory ride height should give you some great and useable travel.sadly I'm just feeding on the crumbs of those who can bake bread on this one . . .
I don't mind a little lift to better clear my 35sIn my mind the perfect scenario is useable travel without lift. So front OEM spacer, rear shock relocation, rear bump stop spacer and extended rear brake lines. Couple that with a sensor adjustment to hit close to factory ride height should give you some great and useable travel.
For AHC “long travel”sadly I'm just feeding on the crumbs of those who can bake bread on this one . . .
AHC Long Travel / Lift?
Back End $650
Rear bumpstop $90
Overlanding Gear | Perryparts - Overlanding Gear | Perryparts - https://www.perryparts.com/shop
Front End $525
Front spacer (20mm) $75AUD (or 4x 10mm spacer from Partsouq, $100 + studs $20
Extended Bumpstops $120
Panhard (to recenter rear after lift/messing with stuff) $345
yeah, but maybe St. Patricks day sales will catch on.With only sensor lift max on front yeah, that’s pretty much it. Dont give away the secrets all at once though sheesh.
If youre crazy like me you can always add trailing arms but thats pretty nitpicky and not really needed. Plus, black friday is not fir a while and i know youre a sucker for a good deal Haha
For the front, it would be interesting to get ahold of the LC diesel spec AHC front springs. I'm assuming these are incrementally higher spring rate for the heavier diesel drivetrain. Partsouq - https://partsouq.com/en/search/all?q=48131-60E60
48131-60E60
I had no idea this was an optionFor the front, it would be interesting to get ahold of the LC diesel spec AHC front springs. I'm assuming these are incrementally higher spring rate for the heavier diesel drivetrain. Partsouq - https://partsouq.com/en/search/all?q=48131-60E60
48131-60E60
Too bad it's not available.For the front, it would be interesting to get ahold of the LC diesel spec AHC front springs. I'm assuming these are incrementally higher spring rate for the heavier diesel drivetrain. Partsouq - https://partsouq.com/en/search/all?q=48131-60E60
48131-60E60
Can you add some more context to this? You're running out of droop still?Honestly, the front shocks still tap out at full droop when driving swiftly off-road.
Yes, In high i consistently run out of droop. 3 stock arm options:Can you add some more context to this? You're running out of droop still?
1: longer coilovers (lx600) integration.
2: put a sway bar back on and lose articulation
3: jump ship and move to an extended conventional coil over.
I’m making moves to go to a tundra swap, see what that does. I also have a lx600 frond diver shock on order to play with and look at.
Update for those that pre-ordered. I dropped the parts off at my anodizer today.
I may have to ream out the anodizing out of the main mounting hole as it is a tight fit on my stock shock mounts. Other than that everything seems like a good fit.
