plink01
- Thread starter
- #41
I installed a rear Lockrite difflock. (Aussi locker). It was pretty easy really, I just had some dramas that were self inflicted.
Once I put the gears in and took the measurement my clearance appeared to be too small. Which seemed to be the opposite of most people who's clearance's are too large.
I measured it about a billion times and decided i needed a thinner spacer. So I ordered one from Toyota and it turns out I'm an idiot and I bought a thrust washer instead. So after waiting for a week for it to arrive it was the wrong thing and its non refundable. So I now have a $30 washer I will never use!
I decided to measure it again for the trillionth time thinking I must be doing something wrong. I measured every piece of the locker with the digital veneers and I put the smallest ones all on the tightest side and it worked! Even though the thickness differential of a part might have been .001mm, when put together with the other parts that were also I micro millimeter smaller it was enough to make it work.
So I put it all back together and got the misus to give me a hand to test if it worked and it failed! I felt like I was going to throw up, what should have been an afternoon project had already blown out to a week or so. Now it didn't even work!
I sat down and calmed down and read a heap of stuff online and called her in and tried again. I was more forceful this time and it worked. I think as I hadnt refilled the diff with oil yet, the grease used during assembly was preventing the locker from working correctly.
I was super happy but still a bit nervous for the test drive. I creeped the car out of the shed super slowly and listened for any sounds that sounded like the diff was gonna explode. But all good! It seems to work fine. I took it out to the bush down the road and I got both wheels to spin up on a steep hill in 2 wheel drive.
I'm really happy with it so far, I havnt heard any clunking or banging people sometimes complain about. You wouldnt even know it's there unless someone told you. Maybe because my clearance are so crazy tight it makes it work better, I'm not sure. I have been driving it a little bit slower in the wet at high speeds but it's still never given me an indication its gonna do something strange and have the back end light up.
Super clean gasket surface! It was another pain in the ass, the old gasket wouldnt budge and was turning into a nightmare. I bit the bullet and wire wheeled it off with the drill.
