wantatlc said:Ummm... I think so, but to be clear (and forget about the L2 mod for this stock setup understaning):
-you drive around in H2 daily
-and you could lock the front hubs in H2 and get a benefit in certain conditions?
Under normal daily driving conditions H2 with hubs unlocked is what you want. If you drive around in H2 w/ the hubs locked your gas mileage will suffer and there is no benefit other than that if you do encounter bad conditions you could engage 4H without having to stop and get out of the vehicle. I leave the hubs locked in the winter for extended periods but not as a habit at any other time.
wantatlc said:-you could drive in H4 without hubs locked and it is better than H2 in certain conditions?
No. In this case you're spinning the forward drivetrain and getting no benefit from it. Your rig will have a mighty thirst though.
wantatlc said:-and/or you could drive in H4 with hubs locked in and it is even better
Only off road or in the worst of onroad conditions (like snow / ice). If you're on pavement w/ H4 engaged and locked you're putting premature wear on your 4wd & tires and you're likely to have a problem trying to disengave 4wd once you stop as the forward drivetrain will be bound up.
wantatlc said:-you could drive in L4 without hubs locked and it is better than H2 with locked hubs?
Only in rare circumstances which I've just learned about after 30 years of four wheeling. You'd need to have a rear locker to take advantage of this too.
wantatlc said:-and/or you could drive in H4 with hubs locked in and it is best for true 4x4 situations
Correct.
wantatlc said:I am just trying to understand all the possible combinations as I thought all there was was H2 then down to H4 and hubs must be locked or it was pointless and then over to L4 and hubs must also be locked or it is pointless. I assumed if you ever get out of H2, front hubs had to be turned and locked or the H4 and L4 were not truly engaged?
Correct. If you want to be in 4H or 4L you must have your hubs locked or you're not in 4wd.
