the idler slinger should be fine, try to straighten it. but don't go overboard or it'll crack. you don't want that puppy to come apart ........
sometimes the idler shaft wants to get gauled into the rear case half. it's because the bare end sticking thru the rear half is steel and will rust slightly. so most of the time i take a wire brush and clean up the end of the old idler really well so it dones'nt wedgy itself into the case half. i also slightly tap on the idler shaft while pulling on the rear half to prevent the idler from having any issues.
i say get some fine grit sand paper, clean up the orfice, run the idler shaft o-ring with a little silicone to help it slip in place and prevent any leaks and you should not have any issues with it. i put a small amount of silicone on all my idler shaft o-rings, be it an early case, an orion or a split case. prevents the o-ring from being cut during install and it definetly helps to prevent idler shaft leaks.
hth
georg @ valley hybrids
hth
to press the clutch hub, bearing and high gear off (after taking off the snap-ring).
I was holding tried and true to the FSM ‘cause I didn’t want to miss anything. Well, when the step you’re doing isn’t in the manual you’re likely to miss it. Sometimes it pays to do what you know is right (or what others from this forum have done/taught before!)!
– a two by four on one side with a couple of small open end wrenches to keep the 2/4 shift fork shaft seal off the deck, a 4x4 and 2x4 stacked against the other side to make it all level…but it all worked. Pressed slowly and everything seated. I pressed against the snap ring on the bottom (out) side of the bearing. I figured worst thing the snap ring would let go, but I had an extra.
