- Joined
- Jun 21, 2011
- Threads
- 233
- Messages
- 21,831
- Location
- Redding, California
- Website
- trail-tailor.com
HDJ is taking up a lot of his time I bet.
J
J
Can you spray bed liner over the "quiet crap"?With most of the urgent mechanical and baseline stuff feeling pretty good, I decided to put some time into creature comforts: Carpet and sound deadening.
Pulled the very faded and nasty carpet, then spent the better part of the day cleaning and vacuuming.
Started in the back and made quick progress putting QuietCrap (80mil) down
So far so good. At this point, I could almost imagine hearing the sound coming from my speakers...
Fast forward a few hours and new carpet (and padding) is in. Thanks to @reevesci for the quick turn around on the carpet kit. Awesome stuff!
Still have most of the 2nd roll of QuietCrap left for the doors and tailgate and a few loose ends to tie up, but so far so good. With just the floors done, the truck is noticeably quieter and the new carpet is really nice. Only drawback is the truck smells slightly less like an old taxi.
Agreed, I have it all. Some day I'll need an engine swap, V8 or BT 4-6.I'll give you an intervention right now:
You can easily burden down your cruiser with several hundred pounds of bolt-on candy.
Think twice (or maybe tree times) before heading down that heavy road.
It all adds up.
Motion to revive this thread - I love this truck. What has happened since November '16???
Wow man, thanks for the kudos! Glad I was able to help from all the way across the USA!Making progress!
Unfortunately, the poor idling condition that magically vanished, magically returned on the way back from a shake down run.
After poking around in the engine bay and reading and rereading carb and smog threads here, I decided to take a hammer to the EGR valve. I'd tested whether it opens by applying vacuum and could hear it move, but wasn't getting a good sense of it closing. Symptoms seemed to match a stuck open condition, so out came the hammer. After a couple smacks, the EGR valve closed, idle smoothed out, and I was able to bypass temporarily by cutting off vacuum to the EGR valve.
I'd been delinquent on adjusting the valves and with the truck idling and running reasonably well, through the time was right. I pulled the plugs and distributor cap, rotated the engine using the alternator bolt until the stars aligned on the flywheel, and dug in. The valves (both intake and exhaust) on 1, 2 and 5, 6 were tight and the rest oddly loose.
Fired up the engine and found idle vacuum went up and the engine had smoothed out, both in small, but appreciated amounts. On the road, the truck feels a bit smoother and seems to pull better. Nice improvement for the cost of a gasket and a couple hours of work.
Picture because people like pictures
Next up: Adjust idle mixture a bit (AFR reading 14.4) and dial in the ignition timing.
Thanks to @NeverGiveUpYota for her many posts on working through similar issues!
