Left hand prep for Moab.
Northern Colorado
Took a test run up Left Hand Trail just outside of Boulder today. Man was that fun!
and just to keep it somewhat tech related, should I remove the rear tire lift assembly, or just zip tie it up so the chain is out of the way?
Cruiserdrew
On the way there
Sacramento, CA
Nice bumper!
I'd take off the spare tire hoist.
Ft. Worthless, TEXAS!
i had mine ziptied for a long time till something got under there and ripped it back down... now i just let it hang i reacon ill remove it all the way once it actually catches on something.
nuclearlemon
not an addict
Moderator
windy wyoming
i removed mine since every time i was under there, it would remove portions of my hair. :rolleyes:
Murfreesboro Tenn.
Take it off.
Denver, CO
I actually took mine off, cleaned, painted, and greased it, reassembled, and put it back on. (After removing, sanding, and painting the crossmember.) Works like a charm now. But then again, mine is not a heavy-duty wheeler.
brownbear
Mod in Hibernation
Moderator
North West Ontario
You have a rear tire carrier, remove it and sell it. That is if it's in operational shape. Mine was corroded so bad I had to cut the chain to get the tire out.
If they work they are handy for normal driving. I use mine on the 80. I don't like tires inside the vehicle, too unsafe IMOP. Unless they are really tied down.
Northern Colorado
Mine was working just fine B 4 I got the new bumper , but the new bumper does not have a hole for me to insert the rod to operate it. So I guess it is going to come out.
Anybody want to buy it? :p
$30 and it is yours!!!! :D
