leaking gas from top of tank
I just found and fixed my leaking gas tank, and installed the GM charcoal vent canister.
The gas tank leak was exactly the same location as others show in their photos. Small crack, maybe 1/4” or 5/16”, and it was tight, hard to find. The metal in the area around the crack was slightly distorted. I don’t see the crack increasing in size as long as the charcoal canister does it’s job and keeps the tank from pressure cycling. The tank pressure cycling between pressurized and depressurized causes fatigue failure at the crack initiation site. That’s why the crack is in the same spot on everybody’s tank; the area that gets the most movement from pressure cycling, and a geometry prone to cracking (stamped rib in the tank top). Think of it the same way a piece of metal breaks when you bend it back and forth many times.
It was super simple to partially lower the almost empty (on reserve) tank on a jack, and access the top of the tank from the front. Make sure you disconnect alll hoses, electrical connectors and fill nozzle hose and vent hose. You will need to lower the tank maybe 8” to get enough room to work in there. My truck is lifted 2-1/2” so I was able to sit at an inverted position and get my shoulders and head, and 1 arm up in there to clean the paint off by hand with coarse sandpaper. Or, you can use a grinder and blow-up 😩
I cleaned all the paint off the tank 1-1/2” around the crack I used JB Tank Weld, which is a 2-part putty, I made a putty patch that was 1-1/4” in diameter, and 1/8” thick. I tapered the margins to the tank, and painted any remaining bare metal.
I know there are those out there who likely believe this repair epoxy repair to be sub-standard, but after I looked at the situation, I believe the structural integrity on the tank will remain, post collision, at least up to the point where the original (new) tank would have. It’s a tiny crack and in an area not prone to ripping or failing catastrophically.
Address your leaking tank - I’m glad I did.
Thanks for posting this! I'm about to give this a go. When you say disconnect all electrical connectors are you talking about the ones on top of the tank through the access hole under the second row seats?
We just drain the tank at the plug on the bottom, then we completely remove it from rig. MIG, TIG, braze,epoxy. All work pretty good. Epoxy has the most fails, but they are few and far between.
Yes, I disconnected all of the tank’s top side pipe and electrical connections that are accessible from the access panel under the passengers seats area. As well, I disconnect the large gas fill hose and vent that come into the rear of the tank.This is because you must partially lower the tank from the front edge to get enough room to work between the top of tank and the bottom of the floor pan.
Be sure to use a high-quality penetrating oil like Kroil on the cinch bolts that retain the straps, for several hours / days so you don’t break the straps.
Check-in: It been several months, two off road trips, and 5k miles and no leaks. Also, the initiating root cause, tank pressurization / depressurization has been eliminated with the GM charcoal canister- no more whooshing sound when I remove the gas cap to fill up !
Add me to the list.
1996 80, running my 2nd Autozone VC-120 charcoal canister since approx 2012, newer gas cap and mine is leaking from approx same area on the forward inboard side of the tank.
The access to fuel pump cover area is dry. Only leaking down pax side and forward when full.
Need to drop tank to confirm though.
Well that took a little while to get to.
I finally just got around to dropping the tank.
Have a new tank to go back in once the sub-tank float switch bung is swapped over.
Edit - It turns out my tank did not have the dreaded tank split.
My leak(s) were from the screw holes in the added bung for the sub-tank transfer float switch.
Not arguing that a more rigorous approach by the community to reporting the problem to the NHTSA might finally yield results, it's worth noting that a solution wished here be a few in this thread is already in hand - and currently even in stock. Long Range America offers a 37-gallon replacement tank.
Sure, it's not cheap, but a Toyota tank, assuming it's even available new, would likely soak up pretty close to the same cash - and have the same old inadequate capacity and likely the same potential for future failure.
I've been very happy with mine. It took my tech half a day to install. Didn't even leak when I flopped the rig over on it's side in a rainstorm of Stony Pass outside Silverton last week...but probably lucky the fill-'er-up side was up, of course.
As you can see, it fits up tightly so not something that would need worrying over any more than OEM.
"......For those trying this at home, I got the tank out without removing the rear axle--at first it looked hopeless, but after a small game of Tetris it came right out."
Who in the world has been removing their rear axle to fix this??
In other news, add another ['97] to the list. Think I'm going to deal with it through the winter before I start removing things to investigate. May go ahead and replace the charcoal canister as preventative maintenance however.
In other news, add another ['97] to the list. Think I'm going to deal with it through the winter before I start removing things to investigate. May go ahead and replace the charcoal canister as preventative maintenance however.View attachment 4075504
Remove the rear driveshaft but not the axle. It's not that bad of a job to swap out a tank but make sure that it is empty.
So you basically created your own leak? If so, I'd say that's likely a one off scenario yeah?
The solder at the bung failed and pressurized fuel leaked up through the machine screw hole and fuel seeped down the tank similar to how the cracked tank issue looked
you can also smoke the tank to see if its the tank, the gasket, fill pipe, charcoal hoses. just need to plug up the charcoal cannster otherwise youll lose all your smoke out of that. i smoked mine recently and put my mind at ease for sure. along with a bore scope.
Another check-in on my epoxy fix to the top of the tank back in ‘23. It did not hold up more than a year.
So I dropped the tank, brought it to a radiator repair shop and they drilled the crack, welded it, then welded a patch over the top.
Now at another 3 years and 30k+ miles, still no leaks.
Additionally, when I fill up with gas, no whooshing sound, ever. The GM-sourced charcoal canister is working very well.
LESSONS LEARNED
1) Pay attention to your truck. If you hear a whooshing sound when removing the gas cap, that is not normal (like I thought it was) and will cause you tank to repeatedly flex and eventually crack at the weak point at the top, towards the front.
2) Epoxy is a temp repair- unless you really enjoy working under you truck, use a more permanent solution.
3) The General Motors sourced charcoal canister (mentioned in other posts) works well and is easy to install in the stock location.
